Any Reason To Choose Rolair Over Makita
Old 07-01-2011, 02:37 AM   #1
JT Wood's Avatar
Trade: carpenter
Rewards Points: 2,494
I need to get a midsize compressor that is portable
I was going to just get the makita 2400
http://www.makita.ca/index2.php?even...id=250&catid=4
Then I saw this rolair with the IDENTICAL specs. (even 1700rpm)
for the same price. ( I assume the motor is the same)
http://www.rolair.net/products/spec_...0TB.html#specs
Is there any reason to choose one over the other?
They cost the same
Or are either one going to last for 10 yrs.
Airdrie AB Renovation Contractor | Kitchen Renovations | Basement Developments | Facebook
JT Wood Construction Serves Airdrie, Cochrane, Olds, Mountainview, Rockyview and Crossfield, Alberta.
JT Wood is offline
Old 07-01-2011, 02:55 AM   #2
Dirtywhiteboy's Avatar
Rewards Points: 7,876
Re: Any Reason To Choose Rolair Over Makita
HJ, the first thing I see is the tank size, the Makita at 4.2 and the rolair at 3.2. I all ways go with the double wiener and not the single wiener because sometimes I need more air and for lasting 10 years not if you run it 8 hours a day 5 days a week with 3 guns in it we use the Dewalts all day every day and toss them away when they are done there Is not much you can do as far as maintenance on those things clean the air filter and I'm been told by the Dewalt rep that the oil never needs changing So my Dewalt has been hurting so I pulled the head off and cleaned with a rag the carbon out and off the valves I guess they are. They are little metal flappers over the ports and I'll see how it worked tomorrow well that's all I know on that
Dirtywhiteboy is offline
Old 07-01-2011, 05:32 AM   #3
Nail-Bender
Brutus's Avatar
Rewards Points: 2,020
We got the makita one at work. I haven't used the rolair one..
No issues here, we've been using it for just over a year and no real issues. Kinda awkward to carry, I find you have to grab by the sides of the grab bar instead of the top where they have that rubber handle.
Brutus is offline
Old 07-01-2011, 05:56 AM   #4
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Right...and the oil in your car never needs to be changed either.
Those valves your cleaning are the reed valves and cleaning them should help it perform better if they were all carboned up.
TBFGhost is offline
Old 07-01-2011, 01:39 PM   #5
Railman's Avatar
Trade: Railing
Rewards Points: 263
I'd bet they both use the same pump, or are manufactured by the same co. Fini makes most of the better pumps of that type. I'm certain that Roll-air uses them, &Mk probably does too.
http://typo3.finicompressors.it/file...ompressors.pdf
Joe
Railman is offline
Old 07-11-2011, 09:34 PM   #6
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,168
Send a message via MSN to KennMacMoragh
I've owned that Makita one for a few years now. So far so good, quiet and starts up every time. I got the Makita because it was the only one with a nice handle to open the air valve. I was sick of the ones without a handle and having to spend 15 minutes every day in the winter time trying to turn it.
But it looks like that Rolair has a handle on it too, why don't you try that one?
kenparsonscontracting.com
KennMacMoragh is offline
Old 07-11-2011, 09:48 PM   #7
JT Wood's Avatar
Trade: carpenter
I was going to get the rol-air, because it seemed like it would class up my trailer a bit better, but when I got to the store, the makita was $60 cheaper so I bought that one.
You are right, it's very quiet and has a low amp draw.
It is approx as loud as my belt drive garage compressor.
I shoulda tossed the old twin stack years ago.
JT Wood is offline
Old 07-11-2011, 09:55 PM   #8
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,264
I have that Makita. My only complaint is the weight but, I should have kept reading after I saw how quiet it was.
I hope the Makita will last me 20 years+. Had it for 3 years with not one hiccup.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 07-11-2011, 10:23 PM   #9
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
ive used both makita and rolair
the makita was the twin tank . runs great for siding with ring nailers and light framing.
the rolair we have is a great big bastard on wheels, its the cats ass for straight out framing running 4 guns. when were sheathing roof we switch it to continous run.
both are heavy
woodworkbykirk is offline
White Makita vs Teal Makita Eckwitte Tools & Equipment 92 03-08-2014 02:30 PM
What brand of cordless tools should I buy hilti, makita, dewalt. Tiptop builders Tools & Equipment 38 06-16-2011 03:58 PM
Makita VS Rol-Air Tank Tools & Equipment 7 06-05-2011 08:07 PM
Different Colors of Makita Cordless DuMass Tools & Equipment 56 02-09-2011 11:05 PM
Makita 5402 16" Beam Saw Austkaine Contractor Swap 6 01-03-2011 08:05 AM
