Aluminum Bending Brake. Which One?
Old 11-18-2007, 09:35 PM   #21
Patrick's Avatar
Re: Aluminum Bending Brake. Which One?
Im thinkin about getting a pro cut off whadda ya think?
Patrick is offline
Old 11-18-2007, 09:40 PM   #22
Sophisticated Siding Guy.
thesidingpro's Avatar
Trade: Siding and Trim Specialist
That would be the only one I would consider. Just because I'm tired of switching blades on my knife.
It would just be another thing in my toolbox and I'd still have to carry a knife so...
thesidingpro is offline
Old 11-18-2007, 09:43 PM   #23
Patrick's Avatar
The ONLY blades I buy now are Irwin blades. The blue one, they are the only ones that dont crack on me right away. Im seriously lookin at the cut off though, does it leave a scar on one side like a utility blade does? I have a brake buddy but that sits in the garage collecting dust too, I can bend faster by hand
Patrick is offline
Old 11-18-2007, 09:55 PM   #24
Al Smith
A W Smith's Avatar
if you snap the very tip of the blade off you can cut off about 1/4 inch of the blade with a snip and you will have a stronger blade with new virgin edge.
Contractor friend of mine bought a cut off wheel. problem is hes left handed and can never get the hang of it with him running off track and messin up the coil. I had no problem with it.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 11-18-2007, 09:56 PM   #25
Patrick's Avatar
nothin like a virgin edge
As for you title, I dumped mine into a coffee can, although some dip, keeps putting the old blades back into the coffee can
Patrick is offline
Old 11-18-2007, 10:14 PM   #26
Funny. I don't find myself trying to find a safe place to dump the old blade. Since I mainly do new construction I stick in a electric box and let the sparky deal with it. lol
Old 11-18-2007, 10:19 PM   #27
Al Smith
A W Smith's Avatar
or you can go into the house and put the old dull blades into that slot in the back of the medicine cabinet. Years later when they open the wall they will wonder who the heck shaved with utility knife blades.
Al Smith
Old 11-18-2007, 11:35 PM   #28
dkillianjr's Avatar
Originally Posted by A W Smith View Post
I didn't think the Windy ever came in a 12'6'
AW, It was a tapco 12'6, it didn't say windy on it or anything, but it looked identical to the windy. It was probly about 14 or so years old when I got rid of it last year. Maybe they used to make them or it was a similar model to the windy. Who knows
dkillianjr is offline
Old 11-19-2007, 12:34 AM   #29
fredhedd's Avatar
Trade: gutter contractor
this is great. this forum is really fantastic. i've gotten all of these different responses and all under a day.
i am kinda surprised that there have been this many responses suggesting the coil holder is unnecessary. i thought for sure this was a must have. it's good to know, though. i'm going to take your words for it and see how i fare with a setup of my own as far as that aspect goes. i was under the impression that a brake was one of those tools where every single amenity was the way to go. what about the foot pedal?
i'm doubly surprised that some of you are still using a knife instead of the cutter. i've never used a cutter before and have only bent about a thousand feet of capping in my life but it seemed like that thing was a godsend. as long as it works as quickly and easily and it looks like it does, i don't think i can be talked out of buying that. thanks for your opinions, though.
sidingpro - your photo is kinda dark so let me make sure i understand your setup. you just have that table behind the brake. the brake and your table are sharing the same horses. looks like your coil is completely out of the box. what is keeping it from uncoiling? what's keeping the aluminum from scatching when sliding across that table?
about the razor blades - i have found it's actually easier for me to score the metal while in the brake after the tip of the blade is broken off. i don't know why but it just works better.
i was planning on coming on here and getting a few vague answers. since i've gotten this plethora of information i'm going to try get as much as i can here and ask some more questions. if anyone thinks i should start another thread i will be more than happy to.
has anyone had a few different kind of brakes in their time and have any noteworthy likes or dislikes. have you gotten rid of one for some specific reason? if you've only ever had a tapco, then sure your going to recommend it. that's usually how that stuff goes. don't get me wrong, it's all good info but if there's any info out there that says one is better than another, i wan it. this is really the only place that i would be able to come across any solid, unbiased (monetarily speaking) info like this. i'm sure as hell not going to get it from the brake companies.
also, can anyone provide more info or tips on how they go about bending a few hundred feet of fascia cap using a 24 inch roll? for instance, do you cut all of the pieces first, then lay them down and mark the bends in some way and then continue to bend them all? is it practical to bend two pieces at the same time when only bending an inch return or something small like that?
theres more i've been using some crappy brake with a lever on one side. the thing sucks in many ways but something i like about it is the measurement on the horseshoes themselves. i thought this was standard thing but i thought i remembered seeing a tapco brake at my supply shop and i couldn't locate the marks on there. did i just miss them or were they missing? if missing, how the hell do you measure?
i thought i had a good idea to make some kind of movable stops on the horseshoes. maybe just on the two end shoes. something that i could easily adjust to stop the metal at certain measurements. is this feasible or am i missing some big reason that this isn't done?
i promise all of you that i have looked through this forum on the sections that thought were relevant to this and i couldn't find answers sufficient enough to all of these questions. i didn't just join and start posting questions without looking for answers first. i realize just wrote sh**load here and i hope it's not a burden. i can't tell you how much i appreciate all of your help. you're going to help me get on the right track with all of this and save me a lot of time and mistakes, though i'm going to make some anyway. so in the end it should kinda work out like this: you help me like you shoulda been helped in the beginning and i'll end up making less mistakes, making more money, and having an easier time than all of you did. if that's not enticing enough...i have a smoking hot sister who i'm sure i could convince to talk to you on the phone for a few minutes. how's that? no, it will not be my grandmother. yes, it may sound like her.
fredhedd is offline
Old 11-19-2007, 01:17 AM   #30
Al Smith
A W Smith's Avatar
Fred.. try the decaf..
just kidding.
I cant speak for others but i love answering questions. please don't apologize for asking. I have only used three different types of breaks over the years. My Tapco windy is beat up and due for replacement. I have never been what you call a production sider. Its just one of the many things I do. Patrick or TheSiding Pro will better advise you. What I can say which pretty much applies to all carpentry work is the less time you spend moving material around the more productive you will be. This means if the material is already in the brake from slitting. You should probably continue to bend it while it's in the break.
(edit to add) my tapco windy has those sliding stops you mention above. I never bothered to use them
Al Smith
Old 11-19-2007, 07:08 AM   #31
Patrick's Avatar
You only need a foot pedal if you are bending really heavy stuff. Like if a hotel specs the wrapping to be gutter metal
I roll out 10 feet on the table, make my measurements on the coil, roll out another 10 feet, mark it, roll out another ten feet so on and so forth till I have enough marked and then I go to town bending.
As far as sizes go make it easy on yourself by making the number come out even. If your facia is 6-1/2 make your return 1-1/2 so you get an even 8. If your facia is 6-3/4 make your return 1-1/4. etc. You can have different size returns on different sides of the house no one will notice. I never liked the idea of those measuring tools that came with the brake. to easy for them to get moved without you knowing. Its pretty fast just marking the coil. Always make sure you cut on the back side of your piece so you cant see the scar when the trim is up.
Patrick is offline
Old 11-19-2007, 07:30 AM   #32
Your correct.
I use the back of the brake for a straight edge and bump a framers square against to cut my coil. Normally there is a piece of coil underneath the roll so that's what stops the scratches.
I only use PVC coated coil with the wood grain so I don't have any scratches.
I promise you that's the best setup. I've got taught by a few different guys and seen a lot of different setups. Mine by far is the fastest most economical.
Old 11-19-2007, 05:18 PM   #33
Patrick's Avatar
I find it more practical to have the table either next to the brake or in front of the brake on the side that you stand on, that way your not walking around the brake to get your pieces.
Patrick is offline
Old 11-19-2007, 07:20 PM   #34
I reach right over the brake. The only time I have to walk around is when I prepping my coil. I use 1/4" cuts and make patterns for all my boards. I start on the table side get all my metal ready on the table and then walk around and bend it.
Old 11-19-2007, 09:23 PM   #35
oldfrt's Avatar
I've kept by work bench (1'2" finished plywood screwed to an old chunk of aluminum ladder)for cutting behind me as I'm facing my brake.Just spin around and switch from cutting to bending.
One short cut I've used,when bending window trim and short pieces with similar profiles,is to cut the coil to twice the length of what you need,cut the width,and then score a mark at the halfway point with your knife.This way you're actually bending two pieces at once ,and ,depending on the number of bends,after a quick snip,the parts can be ripped apart easily.
This works good when bending J's into window trim.You can do one side and one top piece in half the time.
As for holding my coil stock on the workbench,a spring clamp work great.On windy days ,use them to hold the lengths down to the work bench.It also keeps the coil from unraveling so it's easier to put back in the box at the end of the day.
There are so many bends that can be done with a good brake,that you're only limited by your imagination.By bending the J's into your trim work you alleviate one passage for water to get behind the siding.Bending the J into the facia returns looks better than those short pieces of vinyl J
oldfrt is offline
Old 11-19-2007, 09:29 PM   #36
joasis's Avatar
I use a Van Mark, and have a slitter and brake buddy (roll former) both. When taking stock off the coil, I just use the slitter in a jig we made, and that is it. I too wanted a coil slitter, but decided it wasn't worth the bother. I wish my brake was 12-6 instead of 10-6, but that is just a preference.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
Old 11-19-2007, 09:43 PM   #37
oldfrt's Avatar
I bought a coil slitter for a big commercial job 10 years ago.There was a lot of repetitive dimensions and I used 150 rolls of coil.It's been sitting ever since.
No need to spend the money here.It's Ok in the shop,but too bulky to tote out to the normal sized job.
oldfrt is offline
Siding: Aluminum vs. Vinyl Grumpy Windows, Siding and Doors 21 03-30-2010 08:02 PM
Strange aluminum wire ? nywoodwizard Electrical 3 11-15-2007 10:00 PM
Aluminum to copper lug Mike Finley Electrical 21 06-03-2007 12:31 AM
Another aluminum wiring question ron schenker Electrical 18 03-08-2007 06:54 PM
Vinyl over aluminum? Sal616 Windows, Siding and Doors 6 02-20-2006 09:37 AM
