Plumber / Carpenter
Air Compressor
Does anyone know where a site is that explains the way a gas compressor releif valve works, or maybe someone here does. I fixed my compressor, the head gasket had a split, so I replaced it, fired it up and it pumps good now. But now the releif valve seems to be popping on and off very quickly, sounds like a machine gun. I tried taking it apart, spray light lube on the ball underneath, put it back together, and the same thing. I even tried adjusting it up and down. From what I can tell it looks like there may not be enough presseure holding the valve up, I can take my finger and lightly set it on the pop off valve and it will stay open like it should, but as soon as I let it go, it starts popping real fast. I need to try to fix this thing for monday morning, so any help would be appreciated
Old School Marine
Trade: Union Journeyman Electrician
Re: Air Compressor
Replace it the spring must be worn out
#3 | |
Re: Air CompressorQuote:
Plumber / Carpenter
Re: Air Compressor
It is doing it at all pressures. I tried to adjust it. From what I can see, the unloader valve assembly may be bad. I just found out the GC will have temp power on the job, so I can use my electric one. I will call and order the whole unloader assembly monday. Might as well replace it all at the same time.
| canadian tire compressor | Mrmac204 | Tools & Equipment | 5 | 08-06-2007 12:16 AM |
| Hitachi air compressor | Bill | Tools & Equipment | 2 | 06-11-2007 08:30 PM |
| Air Compressor and Power Inverter Question | plazaman | Tools & Equipment | 0 | 12-18-2006 11:06 PM |
| Compressor talk - | Mike Finley | Tools & Equipment | 39 | 11-01-2006 06:29 PM |
| problem with Hitachi Air compressor | Redman | Tools & Equipment | 11 | 04-04-2006 08:12 PM |
