Originally Posted by ewils91
Plazaman, we used to cut off the fitting and replace it with a 3/8 NPT barbed fitting and secure it with a worm drive clamp sized for the hose. Worm drive is what we called them, they are the kind you used to see on radiator hoses that tightened with a screwdriver. We only use poly now the rubber ones haven't been out of the trailer in over 2 years.
You can use a hose clamp, and they do work, but even better, you can buy barbed fittings with a compression clamp- there is a compression nut that goes on the hose first, then the barbed fitting slides in, and the nut is threaded on to the back of the fitting, and tightens down on the hose. It doesn't create another snag point, is less likely to loosen, and looks original. It probably costs less as well, once you consider the cost of the hose clamps.
here is an example of what I'm talking about. You can probably find it locally.
http://www.acehardwareoutlet.com/(js...?SKU=998020348
