Wrinkled Housewrap :(
Old 04-26-2007, 08:32 PM   #1
ecooke21's Avatar
Trade: Rremodeling..finish carpentry, etc
What is the proper way to install housewrap? I always get wrinkles in mine.. it looks sloppy.. I see some house, that look like it is painted on.. I want my jobsite to look like that!!
thanks
sorry if this is a rookie question..
A bunch of little rabbit turds banding together usually just makes one bigger piece of crap. -Mike Finley
ecooke21 is offline
Old 04-26-2007, 08:45 PM   #2
Mod / ArchiBuilder
Cole's Avatar
Re: Wrinkled Housewrap :(
How many guys do you have installing it?
What I do is take 2 other guys and start at a corner and start unrolling while one guy nails the top the other streches and nails the middle and bottom. But try and keep the roll tight and dont unroll to much.
It takes time to get it right and I am sure there is a ton of different ways guys do it.
Cole is offline
Old 04-26-2007, 08:45 PM   #3
AtlanticWBConst's Avatar
Don't you have a laser-aligned auto housewrap spool?
I don't know what else to say than to use the largest width that is suitable for the job that you are doing.
3 person job. Pull it tight, keep the roll tight and tensioned. Tack plumb at the set/install end and smooth it out as you go (like a bed sheet).
Use the house wrap tape on all edges, this also helps keep it smoothed out.
I'm sure there are other tips from members..
- Build Well -
AtlanticWBConst is offline
Old 04-26-2007, 08:47 PM   #4
ecooke21's Avatar
Usualy 2 other gus helping.. I do alot of re-models so I have to go around window casing, electrical services, phone lines, etc.. I guess I just need to practice..
ecooke21 is offline
Old 04-26-2007, 09:06 PM   #5
Mod / ArchiBuilder
Cole's Avatar
Yeah it just takes practice.
Cole is offline
Old 04-27-2007, 08:11 AM   #6
Tom M's Avatar
Use a five foot roll its easy to handle for one guy. Tack staple in the middle every 6 feet or so down the wall till you get to the end, then pull the top and bottom tight while tacking. Re adjust paper if its running away. Never staple around objects till it cut in place or you will get wrinkles.
Tom M is offline
Radiant barrier and Housewrap??? Charles Bagley Carpentry 18 02-01-2011 10:18 PM
Rosin paper or roofing felt? Mike Finley Flooring 35 01-06-2009 03:06 PM
Radiant Barrier and Housewrap? Charles Bagley Construction 0 02-17-2007 02:19 PM
housewrap for wood siding? georgia dawg Carpentry 5 09-10-2005 07:47 AM
