Would Removing Vermiculite Be Considered Asbestos Remediation?
Old 07-14-2009, 09:43 PM   #1
bob_cntrctr's Avatar
Trade: renovator
Gentlemen,
I'm looking at taking on a new rehabilitation project. An old Victorian - built ~1890 - big red brick thing. These things sometimes have vermiculite in the walls or roof as insulation. I know some vermiculite contains asbestos. So would opening the walls to get it out and re-insulate fall under asbestos remediation rules? That is, if I find vermicultite in there, does what I thought was going to be a straight forward open, re-do, close-up job suddenly turn into a full-blown asbestos remediation I have to call specialists in for?
Thanks.
bob_cntrctr is online now
Old 07-14-2009, 09:49 PM   #2
I like Green things
WarnerConstInc.'s Avatar
Re: Would Removing Vermiculite Be Considered Asbestos Remediation?
Have a sample tested if you really want to know for sure.
WarnerConstInc. is online now
Old 07-14-2009, 09:53 PM   #3
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
That's the responsible thing to do. For you and the occupants. Maybe you'll be lucky, but better sure than get in a big can of worms.
Good Luck
silvertree is offline
Old 07-14-2009, 10:03 PM   #4
Ed the Roofer's Avatar
Trade: Roofing Contractor
In many areas, asbestos regulations do not apply when it is a residential property.
Still, test and be prudently safe.
Ed
Ed the Roofer is offline
Old 07-15-2009, 07:26 PM   #5
Bob Kovacs's Avatar
Trade: Consultant
If there's asbestos in the vermiculite (and you won't know unless you have it tested), I'd treat it as a remediation project even if the state doesn't require you to. What happens when the homeowner develops lung cancer a few years down the road and starts thinking "hmmm...Bob took all that asbestos-laden insulation out without proper containment and ventilation- he must have caused this!" It's not worth risking your business to save the owner some $$.
Bob Kovacs is offline
Old 07-15-2009, 08:37 PM   #6
painterman's Avatar
Trade: Historic Restorations
Well said Bob
painterman is offline
Old 07-15-2009, 10:07 PM   #7
Trade: renovator
Ya, ok, message received everyone. Thanks. Very sensible.
When I was a kid on the farm we mixed bags of vermiculite into soil for potting - it just seems odd to imgine it as something dangerous.
Old 07-16-2009, 06:07 PM   #8
72chevy4x4's Avatar
once you find asbestos in the walls, it is an abestos remediation project. what if you blow in insulation from the top of the stud bays-would it be possible to fully settle and not have any original material blow out during the initial installation?
72chevy4x4 is offline
Removing studs from a load bearing wall. Russ25nys Framing 36 06-13-2009 09:52 PM
Asbestos and Popcorn A+ Texture Drywall 15 02-18-2009 09:29 PM
Need some help on Removing Asbestos Siding TurnkeyConst Construction 7 12-02-2007 07:55 AM
Removing asbestos floor tile: Space suits needed? Ted W General Discussion 19 01-29-2007 02:38 PM
