Wood Foundation
Old 01-29-2007, 07:55 PM   #1
maderuyck's Avatar
Wood Foundation
anyone ever heard of a panelized wood foundation system? The only info I can find on them is from the company that installs it so they might be a little biased.
minnesota mike
maderuyck is offline
Old 01-29-2007, 09:53 PM   #2
georgia dawg's Avatar
Trade: general contractor - SFR
Rewards Points: 75
Re: Wood Foundation
You can DIY. In fact, I built a small one to bump up a poured wall that was 3 ft below grade at one section (long story). I gathered all my documentation and ran it by the local building inspector first, though. In fact, I heard the Empire State Building is built on a permanent wood foundation. Check out www.southernpine.com and follow the "applications" link for more info. It's also explained in the 2003/2006 IRC, but you should always check with your local building official to be sure their on the same bandwagon/wavelength.
Hint: Don't cheat yourself when doing this. Be sure all your wood is treated/rated for below grade. It usually has a higher chemical content that regular p.t. wood. Although most of the wood was marked, I actually had to show receipts to the building inspector to verify this fact.
"How much per sq.ft? Well.. gimme $1K and I can build a shed. Gimme $1M and I can build the same size shed with gold plating and encrusted diamonds."
georgia dawg is offline
Old 02-09-2007, 06:54 PM   #3
PHI's Avatar
Trade: Home Construction & Excavation
Re: Wood Foundation
For get it, unless your in a dry area. Pressure Treated lumber will rot over time, approx 10 years. Then you've got to deal with the pressure on the walls fom the exterior soil. Have you ever picked up a shovel of dirt. Well add that by every inch you go down
PHI is offline
Old 02-09-2007, 11:27 PM   #4
Dustball's Avatar
Re: Wood Foundation
minnesota mike
Are you talking about Woodmaster Foundations? If so, I talked to them at Glenbrook Lumber last summer and I was very interested in it. I did my research and the permanent wood foundations are used frequently in Canada and the northern climates. I don't see a downside to it.
Dustball is offline
Old 02-10-2007, 05:46 PM   #5
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,866
Re: Wood Foundation
There is one downside that has plagued the "All Weather Wood Foundation" system for over 30 years.
Wood, when loaded, especial with high moisture contents, has a long term, or possibly permanent deformation or creep. The wall may be strong enough, but it does continue to deform. Excavate the soil behind it, and it does not return to being straight unless you apply an opposite force and are willing to wait a few years to backfill.
This deformation also adds to the stresses in the wood since you end up applying a vertical load (weight of the house, etc.) to a non-straight piece of wood. We all knows what happens when you apply a load to a crooked column. These additional stresses contibute to further bending of the walls. Often, this also causes the top of the foundation to deflect inward and separate from the house, which fortunately minimizes the damage to the house.
On projects I have seen, if this deformation occurs, the only successful method of repairing and straightening the wall is excavation, pushing out the basement wall to straighten everything. After that, permanent shear walls were built inside the basement, perpendicular to the exterior basement walls so backfilling can take place.
This is ready not a "stress" structural problem, but a deformation problem due to the deflection when the basement is subject to high lateral loads.
The system is an engineered system and requires everything to be exactly as planned and assumed. Unfortunately, this does not alway occur in the real world when when you are dealing with organic materials (wood), soil and moisture. A minor drainage problem and wet soil can overload the walls causing unanticipated deflection.
The problem is a material and site problem that panelization does not address or solve. Rot or deterioration is a totally different subject.
Dick
concretemasonry is offline
The Following User Says Thank You to concretemasonry For This Useful Post:
PolycoreGuy (06-12-2014)
Old 02-18-2007, 11:09 AM   #6
It's all about the Avatar
woodmagman's Avatar
Rewards Points: 1,016
Re: Wood Foundation
minnesota mike
You panelize a wood frame structure if you build them prior to erection. If you build the foundation in an erect state the wall is not panelized.
woodmagman is offline
Old 03-08-2007, 12:13 AM   #7
Rollo's Avatar
Trade: home builder
Re: Wood Foundation
The advantage of an AWWF is speed. You can have it up in a day, rather than the poured foundation process which takes over a week, including cure time, before you can backfill.
Check out Superior Wall. Same idea, but done in concrete.
Rollo is offline
New kind of Pressure Treated wood karma_carpentry Carpentry 23 08-21-2008 09:06 AM
Foundation repair (New business) Help! crosshair66 Business 10 05-18-2008 09:19 AM
Pressure Treated Wood rjordan392 Carpentry 4 05-28-2007 02:23 PM
Wood people I need your help Floorwizard Flooring 11 05-18-2006 09:07 AM
