Window Header Question ????
Old 10-16-2008, 08:13 PM   #1
davinci's Avatar
Trade: roofing
a siding customer wants a window ireplaced with a larger window. obviously she now needs a larger opening. the window is 32 x 50. she wants it now to be 36 x 52. what size header you guys recommend? 2-2x 6's with half inch in middle or2- 2 x 8's?
davinci is offline
Old 10-16-2008, 09:06 PM   #2
indm45's Avatar
Trade: roofing
Re: Window Header Question ????
is it a load bearing wall,if so i use dbl 2x12 with plywood
indm45 is offline
Old 10-16-2008, 09:20 PM   #3
davinci's Avatar
Trade: roofing
its a bi level; top floor in the dining room? only a roof over it.
davinci is offline
Old 10-16-2008, 09:26 PM   #4
odellconstruct's Avatar
Trade: carpenrty, remodeling , residential
2x6s or 2x8s should be more then enough to carry the weight at a 36 in span . 2 x 12 would be a lil over kill , would recommend fir , not spruce .. good luck
i would also check your local codes as well just to be sure if unsure .
odellconstruct is offline
Old 10-16-2008, 09:36 PM   #5
davinci's Avatar
Trade: roofing
when would a steel header be used?
davinci is offline
Old 10-16-2008, 09:41 PM   #6
Dan_Watson's Avatar
Anything over 37". You just made it.
Dan_Watson is online now
Old 10-16-2008, 09:45 PM   #7
used for larger spans to reinforce , such as load bearing walls . garage doors , large window openings 8 ft and above an i beam or steel reinforcement will benifit ,
Old 10-16-2008, 09:54 PM   #8
with a 36 ''r.o your header should be around 39''
Old 10-16-2008, 09:56 PM   #9
Dan_Watson's Avatar
I can't say I have ever seen a steel beam used for a header in a residential structure. Usually they are some form of engineered lumber. Dimensional lumber can span up to 12' for a header with a roof and ceiling load in some situations. Every situation is different.
Old 10-16-2008, 09:57 PM   #10
Dan_Watson's Avatar
I was being sarcastic....
Old 10-16-2008, 10:10 PM   #11
just stating the facts
Old 10-16-2008, 10:15 PM   #12
Dan_Watson's Avatar
I would have overlooked that and been cursing up a storm when I had to build another header
Old 10-17-2008, 12:07 PM   #13
Cst Dsn Bldrs's Avatar
Trade: Custom Design-Build Firm
Dont know about ya'll, but here in alabama we use the 2003 International Building Code. and header under 5', only have to use one jack stud. Therefore, the header will be 3" larger than the rough opening. Over 5', use two jack studs. Load bearing wall or now, we always use 2x10's with 2x4 on top (Header measures 11", duh).
If its a long window, use engineered beams (LVL's)... metal is too expensive unless wood wont work.
Cst Dsn Bldrs is offline
Old 10-17-2008, 06:25 PM   #14
Tom M's Avatar
Do yourself a favor measure the head space over all the other doors and windows inside. Its likely at least 12". So instead of guessing proper size and then putting little cripple studs in the remaining space just put in a 2 (2x12) Unless that encroaches on your space for the window it will be completely over kill. In case someone adds onto that split level later it will be fine. FYI the code book makes a suggestion based on what it supports above so when the size you need takes up too much space you can then go to steel to increase strenght on slimmer sizes. And always leave those wall plates in!
Tom M is offline
Old 10-28-2008, 09:23 PM   #15
codaman's Avatar
Trade: Skyhook operator
I would make sure that the window heights remained consistent throughout the house. If there was a 2X6 header, you may not want to put in a 2X12 and drop the window that 6 inches. You could also use LVLs. Good luck
codaman is offline
Old 10-29-2008, 11:16 PM   #16
whaler's Avatar
Trade: carpenter
when talking about windows and doors, state the width first than the height, codaman brought up the most important point= keep window heads the same height. stuff whatever header fits to make it happen. my guess 2x10/w cap.
whaler is offline
Underlayment question 72chevy4x4 Roofing 12 10-17-2008 01:19 PM
Question for window guys ProWallGuy Windows, Siding and Doors 9 10-06-2008 12:16 AM
HVAC Licensing question kdan General Discussion 2 08-25-2008 09:17 AM
Span question bikerboy Introductions 5 08-23-2008 07:44 AM
Vinyl Window Question joedonuts Windows, Siding and Doors 4 06-11-2006 11:31 PM
