Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Construction
Closed Thread
Old 07-28-2009, 02:26 PM   #1
What size steel beam to use for load bearing wall???
Hey, i need advice on choosing the correct size steel beam. Please excuse my lack of knownledge (Im a carpenter, not builder), i have the way i want to do this in my head, just not 110% on it because of lack of experience
Ok, I am knocking a wall between a kitchen to a living room. The wall is carrying the the 9x2 Joist overhead, The wall is made of 4 inch block. I want to knock the wall clean through, the opening is 3.5 metres (12 feet approx). I was told to leave a 6 inch bearing on the wall, is this correct.
Would appreciate also if you guys told me how you would approach this job. PS (A friend reckons a 8x4 steel steel beam would be ok.... but i am not so sure)
Thanks alot in advance
brianmvp is offline
Old 07-28-2009, 02:31 PM   #2
Trade: Framing
Your friend might be right, but....
Hire an engeneer to look at and size it properly!!
Framer53 is offline
Old 07-28-2009, 02:40 PM   #3
ChrWright's Avatar
Trade: Builder/Remodeler
No one can, or should, tell you how to address a structural issue sight unseen... What someone "reckons" can often get you into serious trouble. You've not even given enough info for an educated guess.
A good lumber yard will have someone who can tell you the specs for a given type of beam... lvl... glue lam... etc. But only a structural engineer can tell you exactly what to use for your actual existing conditions.
Christopher Wright, WrightWorks, LLC
www.WrightWorks.net - Facebook - Christopher Wright, Remodeling Info on Twitter
Indianapolis Remodeling Contractor - Remodeling Photos: Kitchens, Baths, Room Additions, Basements
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again." --Andre Gide
ChrWright is online now
Old 07-28-2009, 02:57 PM   #4
Sorry the joist are 9x2 approx 10ft long in each room. so it would be carrying say 22 joist or so.
the floor above carrying 120 sq ft of 12mm softwood flooring,
the same amount of solid oak flooring on top of this.
A 10 ft stud wall made of 3x2 and 9mm plasterboard
2 beds and 1 wardrobe.
If some1 could give me a formula,
I would give it a bash myself, (Its my own house so not to worried about being libel)
brianmvp is offline
Old 07-28-2009, 03:12 PM   #5
genecarp's Avatar
http://http://www.contractortalk.com...portant-60787/
genecarp is online now
Old 07-28-2009, 03:16 PM   #6
demo master
kevjob's Avatar
Here in Denver when I pull a structural permit and there is no engineers letter they tell you to come back when he signed off on it. No guessing on beams and load points etc...
kevjob is offline
Old 07-28-2009, 03:19 PM   #7
LRG WoodCrafting
Leo G's Avatar
Trade: Professional Sawdust Producer
A big'un
Measure Twice Cut Once -- It's a lot easier to cut more off then it is to cut MORON.
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 07-28-2009, 03:23 PM   #8
ChrWright's Avatar
You are clearly not a carpenter and don't have the chops for what you're proposing. You need PROFESSIONAL help, ON SITE... and not a "best guess" or "reckoning". You're going to hurt someone with your "bashing"--either your own family, or more likely whomever you sell this spec to...
Old 07-28-2009, 03:29 PM   #9
Trade: Home Remodeling
Talking
OP=HO??.. Now, let's da fun begins... OOps.. I meant... Da Bloody Monster Bash!!
SelfContract is offline
Old 07-28-2009, 03:30 PM   #10
demo master
kevjob's Avatar
The next guy might care if it falls down or is undersized.
kevjob is offline
Old 07-28-2009, 03:38 PM   #11
Here buddy, I AM a carpenter, I know exactly what im doing, and how im going to do it!
I was just saying, dat I id give the formula a "bash" (attempt) if i got it. I want to make sure the floor above are structurally sound, if i can avoid paying an engineer to do a caluculation dat would only take 2 minutes.
So dont be coming on here patronising me pal, im just looking for some helpful advice
brianmvp is offline
Old 07-28-2009, 03:46 PM   #12
knucklehead's Avatar
Trade: Framing,Remodeling,General Contractor
I don't think an 8x4 is big enough. I would go with at least an 8x18#
13' long that would be 234 lbs
knucklehead is offline
Old 07-28-2009, 08:12 PM   #13
Are you guys ignoring me?
Old 07-28-2009, 08:23 PM   #14
Al Smith
there are no magic formulas. there are potential errors of omission.
Brian Brian Brian
If you don't already know the pounds per lineal foot of beam including point loads that you are trying to carry, then you need an engineer. My ex father in law who was a retired staff engineer for the port authority of NY used to size my steel for me. why are you afraid to consult one? they don't bite. It could be a learning experience for you.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 07-28-2009, 08:52 PM   #15
Plausible Deniability
JumboJack's Avatar
I would just be safe and go with a three giggawatt beam.Better to be safe than sorry.
"The problem with socialism is that eventually you run out of other people's money."
JumboJack is offline
Old 07-29-2009, 04:51 AM   #16
Framer
Warren's Avatar
Trade: framing/remodeling
Da formula might not be the only thing getting a "bash"
Carpenter here also. Do the math yourself to be sure or call an engineer. Why would you trust the math skills of people on the internet who will hold no liability?
Warren is offline
Old 07-29-2009, 05:56 AM   #17
joasis's Avatar
Enough. Closed.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
405 314 5802
joasis is offline
Closed Thread
Removing studs from a load bearing wall. Russ25nys Framing 36 06-13-2009 08:52 PM
Attaching 2x4 to steel girder Philly Dude Carpentry 20 12-29-2008 11:35 AM
removing a retaining wall Cache Excavation & Site Work 30 07-16-2008 04:57 PM
Steel beam replacement BHI Carpentry 17 02-28-2008 12:03 AM
8" wall size jaymay75 Masonry 5 04-22-2006 12:52 PM
