What Are Crutch Bents?
Old 05-11-2009, 01:21 PM   #1
maurajbo's Avatar
Trade: Construction
If a bridge is supported by crutch bents, what does this mean? Anyone know?
maurajbo is offline
Old 05-11-2009, 07:08 PM   #2
KentWhitten's Avatar
Re: What Are Crutch Bents?
Not really sure, but I did a little looking and found this pdf file with many references of crutch bents.
http://www.dot.state.fl.us/statemain...aintenance.pdf
Salmon Falls Cabinetry
KentWhitten is online now
Old 05-11-2009, 09:59 PM   #3
Cletus's Avatar
Trade: Tube Installer
I had never heard of this term.
From Ohio DOT "Bridge term definitions":
Bent
Part of a bridge substructure. A rigid frame commonly made of reinforced concrete or steel that supports a vertical load and is placed transerse to the length of a structure. Bents are commonly used to support beams and girders. An end bent is the supporting frame forming part of an abutment.
Each vertical member of a bent may be called a column, pier or pile. The horizontal member resting on top of the columns is a bent cap. The columns stand on top of some type of foundation or footer that is usually hidden below grade.
A bent commonly has at least two or more vertical supports. Another term used to describe a bent is capped pile pier. A support having a single column with bent cap is sometimes called a "hammerhead" pier.
I assume a "crutch bent" is placed next to a failing bent to shore it up.
Today is national 'Learn Something New About Bridges Day'!
Cletus is offline
The Following User Says Thank You to Cletus For This Useful Post:
loneframer (05-11-2009)
Old 05-12-2009, 08:12 AM   #4
Structural Engineer
Aggie67's Avatar
Trade: Mechanical, Structural
Decent photo of an end beam crutch bent at this link, on page 62:
http://www.otecohio.org/2006%20prese...ons/gowins.pdf
Aggie67 is offline
Old 05-13-2009, 09:49 AM   #5
maurajbo's Avatar
Trade: Construction
Thanks Guys. That helps a lot!
maurajbo is offline
