Ways To Finish A Concrete Block Wall
Old 04-15-2011, 04:33 PM   #1
3bar's Avatar
Trade: carpenter
Rewards Points: 460
i have an existing building which is constructed of concrete block walls.
i'd like to give the exterior walls a finished look...maybe like stucco or dryvit.
can a layer of concrete be sprayed or troweled over the surface? will cracks show through? any flexible coatings? any specific products to use?
3bar is offline
Old 04-15-2011, 04:36 PM   #2
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
Re: Ways To Finish A Concrete Block Wall
Dryvit can work, you can even add a layer of EPS to help keep it warmer on the inside
Chris
Chris Johnson is offline
Old 04-15-2011, 04:40 PM   #3
Thom
thom's Avatar
Rewards Points: 4,748
In my part of the country that's an everyday job. Just stucco over the block. If you use synthetic stucco for the finish coat you can do your brown coat directly on the block. If you use a standard stucco color coat you might want to paper, lath, scratch and brown before finish. With standard stucco directly on block the stucco dries faster over the cavities than the joints so the joints cure a different shade and are always visible.
thom is offline
Old 04-15-2011, 04:58 PM   #4
3bar's Avatar
Trade: carpenter
Rewards Points: 460
i'd like to have the look of dryvit, but not the expense of doing foam also. can the dryvit material itself be applied to concrete block walls?
interesting point. i wouldnt be against painting over the finish in the end, if shading is a problem.
3bar is offline
Old 04-15-2011, 05:09 PM   #5
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
You would have to parge the wall first, to get a smooth base for the Dri-Vit finish.
I've seen the Dri-Vit finish coat used over stucco brown coat many times.
loneframer is offline
Old 04-16-2011, 03:33 PM   #6
darr1's Avatar
Trade: all carpentry
over here i would put sand and cement on that it would give it a neat finish
darr1 is offline
Old 05-11-2011, 04:14 PM   #7
Free Thinker
Raywill49's Avatar
Trade: masonry
We have a product called ProGaurd. It is a concrete faced insulated sheathing product. You simply screw this to the block wall, tape and seal the joints. This material will increase the insulation value of the wall and replace the scratch/lath coats. You are ready for the finish coat or thin brick/stone application. Should be a tremendous labor savings and you won't have to relying on anything bonding to the CMU.
Raywill49 is offline
Old 05-11-2011, 05:25 PM   #8
General Contractor
greg24k's Avatar
Rewards Points: 7,258
Quikrete elastomeric coating, it can be used to coat concrete and stucco, good product because, it does 2 things, bridges cracks and also seals them to prevent cracking
greg24k is offline
Old 05-11-2011, 09:40 PM   #9
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Give the block a light spray with water then stucco direct to it. Is an everyday thing around here.
CrpntrFrk is offline
Old 05-12-2011, 11:22 PM   #10
dhutchinson's Avatar
Trade: Kitchen Remodel
I'm planning to do this too in the future. The answers I read here really is a big help. Thanks. This is the beauty of joining forums like this. You can get great answers for your construction problems. You all a great bunch of people.
dhutchinson is offline
Old 05-13-2011, 06:02 AM   #11
master hacker of wood
FRAME2FINISH's Avatar
Trade: restoration carpentry
Rewards Points: 1,730
heres a good solution for you, my house is architectural block, very porous jagged stuff, however it isn't cheap
when we did my buddies log cabin he cheaped out and parged his block,
looked like crap when he was done,
so when it was time to do my garage i use cheap block and i used a drywall splatter gun, and portland cement
hell yeah it works good and it holds up well too, and it is goodlooking imo
FRAME2FINISH is offline
Old 05-14-2011, 08:29 PM   #12
3bar's Avatar
Trade: carpenter
Rewards Points: 460
you know, i was thinking of doing that.
anyways, this building belongs to my father. he ended up getting STO brand stucco. we started doing some patchups on friday. hopefully it goes good. we're carpenters, and never done plastering before, lol.
3bar is offline
Old 05-14-2011, 11:34 PM   #13
CrpntrFrk's Avatar
Don't forget the darby!
Help! Hardie Plank stuck to concrete wall TarPaperCrane Concrete & Paving 18 11-22-2017 07:11 PM
Block wall under existing roof/ceiling... StPete727 Masonry 38 07-12-2009 07:57 PM
Setting fence posts on top of concrete retaining wall Tim C. Decks & Fencing 7 06-04-2009 07:16 AM
window return in concrete block house bmancanfly Remodeling 10 05-15-2009 03:30 AM
Best way to fasten plywood forms to concrete block? SK Remodeling Construction 16 03-10-2009 12:46 AM
