Trade: Landscape contractor
Waterproofing Questions
Ok so I am a landscape contractor and I want to do some waterproofing around my home. I have done several french drains, but never around a house. I am planning on doing a french drain w/ drain tile around the house and running all my gutters away from the house. I have water in my crawl space when it rains and it is damp when it is not raining. I have attached some paint sketches of the layout.
Do I need to backfill with gravel all the way down to the footer? Do I need to have the drain tile at the bottom of the footer? Do I need to have the french drain run in front of the garage slab and porch slab? What type of coating would you put on the foundation? I think I am going to use some type of pvc for the drain tile, I really don't have much respect for the corrugated pipe any more... at least in the 4" size. Any help would be appreciated. Last edited by RickW; 11-15-2009 at 04:59 PM. |
Trade: Property Preservation and Remodeling.
Re: Waterproofing Questions
I would call someone who deals with this type of problem.
www.destinyhomesinc.com |
#3 | ||
Re: Waterproofing QuestionsQuote:
#4 | |
Trade: General Contractor, Commercial and Residential
I created a basement out of a very wet crawlspace for a client. The house was on a steep hill and a stream was adjacent to the property. Part of the stream had diverted into the crawl making it a marsh. We put a network of the system described above to direct the water in the crawl back to the stream it came from. It worked very well. We went on to build out the basement which included hardwood floors and we never had a problem. Hope this is helpful
keeverandassociates.com |
Thanks for the responses.
Trade: Masonry
The coating on your foundation can be many different things, depending on what you want to spend....vulcanized sprayed on, very costly, bulletproof. You can also spray that asphaltic, heated. Very good, not too expensive. Thoroseal, brush on. Do it yourself, not too expensive. Parge with many different products, some absolutely bulletproof as well. Do a little research, there are a lot of choices....gl
| Painting business start-up questions | oneelwayfan_com | Painting & Finish Work | 56 | 02-02-2010 01:55 AM |
| Posting Rules Update: How-To Questions | Nathan | General Discussion | 1 | 09-21-2009 03:33 PM |
| Direct mail questions answered | dave3717 | Marketing & Sales | 9 | 11-20-2008 01:43 PM |
| Pricing questions | Brian | Painting & Finish Work | 3 | 10-13-2007 09:38 AM |
