Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Construction
Old 09-15-2009, 02:45 PM   #1
Trade: Tiler
Waste Pipe Outlet Beneath Damp?
Hi guys,
Im curently fitting a bathroom in a bungalow, at the moment im onto installing the new resin shower tray none easy install type which sits on a bed of mortar directly onto the concrete floor.
My question is regarding the waste, with the tray sitting on the floor I'll have to chop into the floor for the shower trap and chop a channel for the 38mm waste pipe, but to keep a fall this means exiting through the external wall about a brick depth beneath the DPC level into the drain.
Is this OK to do? Or will I get issues with damp traking through from this pipe? Or should I just wrap the pipe in some visqueen to keep it from touching the damp brickwork?
Cheers
Steve.
tileman_17 is offline   Reply With Quote
Old 09-15-2009, 03:26 PM   #2
Trade: Remodeling general
What is the pipe made of is it PVC or Iron or brass.
brass I might consider wraping it but not for PVC
naptown CR is offline   Reply With Quote
Old 09-15-2009, 03:27 PM   #3
Trade: Tiler
PVC pipe
Old 09-15-2009, 03:31 PM   #4
don't worry about the pipe but put some plastic over the trench before you concrete it in if you have disturbed the existing vapor barrier
Designing a dust-collection system for my shop: any problem using 6" pipe? Panzer5 Tools & Equipment 24 05-19-2009 09:34 AM
condesating steam pipe Platinum8 Plumbing 6 04-27-2009 07:29 PM
Pre-calculate DWV pipe lengths between fittings? bob_cntrctr Plumbing 1 01-20-2009 01:08 PM
Dead Outlet, Circuit LNG24 Electrical 32 11-07-2008 06:35 PM
Very clean galvanized pipe. silvertree Plumbing 14 09-14-2008 02:47 PM
