Walking On A Metal Roof ?'s
Old 05-12-2010, 10:14 PM   #1
Woodologist
Mr. D's Avatar
Trade: residential construction
Rewards Points: 250
Hi everyone. I have a to get to a section of a house that is above a metal roof to stain. It is quite slick and just a bit steep to walk. I wondered if you all have any suggestions on how to stage this area?
Mr. D is offline
Old 05-12-2010, 10:26 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 478
Re: Walking On A Metal Roof ?'s
Articulating boom lift.
Nice house.
griz is offline
JustaFramer (05-13-2010)
Old 05-12-2010, 10:28 PM   #3
Woodologist
Mr. D's Avatar
Rewards Points: 250
you can do better than that.
Mr. D is offline
Old 05-12-2010, 10:31 PM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 478
Not me. Only way I would even consider doing it. It's fast and easy, no sloppy scaffold set up.
griz is offline
Old 05-12-2010, 10:57 PM   #5
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
If it's just that lower part, you should be able to walk it easily w/ foam rubber.
Just take the covers off your couch cushions...
-Steve
TimelessQuality is offline
Old 05-12-2010, 10:59 PM   #6
rselectric1's Avatar
Rewards Points: 586
All I can offer is saying an articulating boom lift (as Griz said) is my suggestion too.
Be careful up there!!!! Post what you come up with!
EDIT-they're fun to play with too!
rselectric1 is online now
Old 05-12-2010, 11:16 PM   #7
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,496
Suction cup shoes.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 05-13-2010, 12:58 AM   #8
JustaFramer's Avatar
Trade: Exiled For Life
Rewards Points: 2,000
JustaFramer is offline
Old 05-13-2010, 05:36 AM   #9
copper magnet
seeyou's Avatar
Trade: custom metal fabrication
Rewards Points: 512
Vise Grip sheet metal tongs.
Clamp them to the seams with the handles up and set a 2x4 or chicken ladder against them.
seeyou is offline
The Following User Says Thank You to seeyou For This Useful Post:
Tom Struble (05-14-2010)
Old 05-13-2010, 07:55 AM   #10
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extraordinaire
Rewards Points: 1,046
You have some big brass ones to go up that friggin' thing.
Andy.
ScipioAfricanus is offline
The Following User Says Thank You to ScipioAfricanus For This Useful Post:
gdwoodbutcher (05-27-2010)
Old 05-13-2010, 08:34 AM   #11
copper magnet
seeyou's Avatar
Rewards Points: 512
Andy.
Never had one move on me and I weigh 260+. Been doing it for 25 years. But you'll notice that there's scaffold right below and we'll be harnessed when on the chicken ladder.
In the OP's situation, very little force will be exerted on the vice grips since it's a low pitch roof. They will just act to keep him from starting slide. I'd harness off anyway.
seeyou is offline
Old 05-14-2010, 05:55 PM   #12
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
we make a wood ladder out of 5/4 just slightly smaller than the pan and clamp c-clamps to the side of the ladder and the ribs
but don't do this with out an anchored safety line
Tom Struble is offline
Old 05-14-2010, 07:10 PM   #13
Woodologist
Mr. D's Avatar
Rewards Points: 250
i bought a few cheap bath mats. no slip . good times. wall is done. saved big $ on renting a lift. think i'll go catch a tigers game.
Mr. D is offline
The Following User Says Thank You to Mr. D For This Useful Post:
DaVinciRemodel (05-15-2010)
Old 05-14-2010, 08:21 PM   #14
Trade: siding
Rewards Points: 20
hhmmmm... no slip bath mats....whod a thunk
Old 05-14-2010, 10:26 PM   #15
gregj's Avatar
Rewards Points: 150
A lift would have made that whole job a lot easier.
gregj is offline
Old 05-15-2010, 11:52 AM   #16
Sasquatch's Avatar
Rewards Points: 150
Those are some big lincoln logs. Awesome house.
"If the women don't find you handsome, they should at least find you handy". - Uncle Red form the Red Green Show
Sasquatch is offline
Old 05-15-2010, 08:15 PM   #17
Estimating Software
toecutter's Avatar
Trade: Estimator/Software Developer
Rewards Points: 346
Volleys are known as a good roofing shoe, i have used them on metal roofs and they don't slip on step roofs but i would also use a rope or something else in your case to be sure.
Still not that good if the roof is wet
regards
mick
toecutter is offline
Old 05-15-2010, 09:05 PM   #18
cbfx3's Avatar
Trade: Framing and General Construction
Rewards Points: 150
Ive used the vise grip/ c lamp method
cbfx3 is offline
The Following User Says Thank You to cbfx3 For This Useful Post:
seeyou (05-16-2010)
Old 05-16-2010, 05:55 AM   #19
Dan
ApgarNJ's Avatar
I've done this one not so steep metal roofs, use a bunch of clamps, then slide a piece of 3/4 ply against that. and you can screw a 2x4 to that ply to keep your ladder from kicking out if you need to use a ladder while up on the roof. articulated booms can't get everywhere.
also, if you take some scrap EPDM rubber off your roofer, it grips better if you have used the rubber primer on it first and let it dry really well. then it's somewhat tacky but not going to stick or leave marks(test it out first, some finishes might mark up)
then lay the EPDM in the pan where you need to work and it keeps you from sliding.
the foam pads on top of that work well.
I've also made small chicken ladders that fit into the panels using 5/4 lath . you can keep them from job to job.
lastly. if they have snow guards, make sure they are securely fastened and I have in the past trusted them because I know who put them on. Those snow guards withstand lots of force from snow/ice in the winter, just look what it does to gutters without it, that's a lot of force, more than we are putting on them with our weight. so the more guards you can catch to push against, the better you are. bring an allen key up and make sure they are tight.
ApgarNJ is offline
The Following 2 Users Say Thank You to ApgarNJ For This Useful Post:
seeyou (05-16-2010), Tom Struble (05-16-2010)
Old 05-27-2010, 05:48 PM   #20
gdwoodbutcher's Avatar
Trade: carpenter cont.
Not to be a ****, but do you tell homeowner clamps may leave marks. My experience on higher end jobs is customer expects us to walk on water. Leave no trace we were there. Whenever I try to save customer money, it comes back to bite me. I vote for the lift! Know you said bath mats worked, but, one slip with bucket of paint in hand, I'm just sayin
gdwoodbutcher is offline
steep metal roof , help! jdframer Roofing 30 04-19-2015 08:55 AM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 22 01-05-2013 05:42 PM
ISO tips for walking steep roof (asphalt) dproc Roofing Picture Post 19 08-20-2010 07:12 PM
Metal roof question tc70518 Roofing 1 03-12-2009 06:15 PM
rubber roof over rolled asphalt ? ? btownpa Roofing 2 03-06-2009 02:03 PM
