Void Under Garage Slab
Old 11-25-2017, 11:16 AM   #1
dayexco's Avatar
Rewards Points: 624
Son has 3 stall garage with floor drain in middle. Sounds to me area around drain is hollow around drain area. No cracks, settlement.
He's thinking of coring a 4" hole, filing with flowable fill.
Would it be better for him to get someone in there to pump it in there?
dayexco is offline
Old 11-25-2017, 12:51 PM   #2
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 1,712
Re: Void Under Garage Slab
How much of a void? If it's only a cubic foot or 2, getting a truck and pump there probably isn't gonna work.
I know some guys will set the floor drain in gravel. I've always wrapped mine in foam and set it in the 'crete. Don't know if that's the right way to do it.
Delta
I have an Edifice Complex.
Old 11-25-2017, 12:54 PM   #3
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 238
Send a message via Skype™ to jlhaslip
Drag a logging chain or a tow chain across the floor and you will know how far the void extends.
Former company I worked for had a hand grout pump and we would set a wedge anchor in the slab, but with a hole drilled in the wedge. Connect the hand grout pump and fillerup. Sika 212 works fine. mortor over the anchor hole or not. Your call.
jlhaslip is offline
The Following 2 Users Say Thank You to jlhaslip For This Useful Post:
asevereid (11-25-2017), dayexco (11-25-2017)
Old 11-25-2017, 01:03 PM   #4
Trade: Builder/GC
Never heard of that. Does that work pretty well?
Delta
Old 11-25-2017, 04:23 PM   #5
jlhaslip's Avatar
Rewards Points: 238
Delta
Works great. The change in the sound of the chain rattling is a dead give away for the void.
Used it to find voids and separations on Bridge decks with high density overlays.
jlhaslip is offline
The Following 5 Users Say Thank You to jlhaslip For This Useful Post:
AustinDB (11-26-2017), dayexco (11-25-2017), Rio (11-25-2017), Seven-Delta-FortyOne (11-25-2017), shanewreckd (11-25-2017)
Old 11-25-2017, 11:15 PM   #6
3bar's Avatar
Trade: carpenter
Rewards Points: 416
seems like a good idea. i've always just used a hammer and tapped on the floor.
3bar is offline
Old 11-26-2017, 10:59 AM   #7
tgeb's Avatar
Rewards Points: 252
It could be that the slab is reinforced with grade beams and that it is essentially self supporting and the settlement of the soil is no big deal.
Around here most home builders opt for a grade beam slab in the garage so they don't have to be concerned with finding appropriate fill material, compacting the soil in lifts and paying a "dirt burner" to stand there and watch.
www.gebcon.com
tgeb is offline
The Following User Says Thank You to tgeb For This Useful Post:
dayexco (11-26-2017)
Frame garage on slab. Tips and techniques? Willin Framing 5 09-04-2017 04:59 PM
Smoke damaged concrete garage slab fitful2u General Discussion 0 10-08-2013 05:32 PM
Garage slab slope dsnider General Discussion 4 12-02-2011 05:22 PM
Garage slab over existing concrete pjswan Concrete & Paving 1 08-01-2011 03:20 PM
Black marks in new garage slab? wackman Concrete & Paving 18 11-13-2007 07:45 PM
