Vinyl Windows
Old 05-04-2008, 08:58 PM   #1
rayh78's Avatar
Trade: GC - Home repair
Vinyl Windows
Suggestions on a vinyl replacement window brand.
When installing replacement windows without wrapping the trim, I have used a few brands and all have a L shaped trim piece under sill that you first mount to the old windowsill. So windows sit on the edge of this little trim piece. I always considered this a weak link to a install. So a lot of times the whole weight of the window is on this 1/16” piece of vinyl and of course some on the mounting screws in the sides to the old frame.
Always did not like this but noticed more with a 5 ft. picture window with more weight. A proview norandex brand.
I could not get a brand name but have seen one that this trim piece is T shape and snaps onto a groove made in the window. It seems stronger and better way to do it since it is more part of the window.
Thanks for any comments
rayh78 is offline
Old 05-04-2008, 09:12 PM   #2
Patrick's Avatar
Re: Vinyl Windows
On a 5' window you should have shims under it to support the weight. you want either a snap in vinyl sill expander, or an aluminum angle iron. a vinyl angle iron means its a cheap window
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 05-04-2008, 10:21 PM   #3
rayh78's Avatar
Re: Vinyl Windows
That is my question. What brands have snap in sill expander?
I have not found any on Certainteed or Norandex brand windows.
rayh78 is offline
Old 05-04-2008, 10:57 PM   #4
Patrick's Avatar
Re: Vinyl Windows
we use Harvey and they have snap on vinyl expanders or aluminum angle
Patrick is offline
Replacement Vinyl windows Project53 Windows, Siding and Doors 61 03-23-2011 09:02 PM
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
Removing scratch from vinyl windows A.W.Davis Construction 9 09-12-2007 10:28 PM
sq.ft. price on vinyl replacement windows ch0mpie Windows, Siding and Doors 10 08-16-2006 11:22 PM
Brown vinyl windows skidmark845 Windows, Siding and Doors 8 05-31-2006 10:12 PM
