Trade: Total Home Renovation
Vinyl Over Stucco Again HI any experience with this installation: Existing stucco, then building paper,then frame of 2X2 every 16" with 1 1/2" "studs" and styrofoam in b/w More building paper on top Then vinyl siding Besides hard to nail or glue the 2X2 and styrofoam is there any other side efects? like dew point -condensation ,mold? Location -Vancouver -Canada close to Seattle Getting read of the stucco is not an option, and personaly I think it will add an R value to the house insulation but I am not a 100% sure about condensation I have to do it in the next 2-3 weeks Tx Stanley |
Trade: Construction
Re: Vinyl Over Stucco Again
As long as there's good insulation between the internal walls and external walls then you should stop most if not all condensation issues.
thank you very much
Trade: Bricklayer
I maybe late on this but 2 layers of building paper with wood in between sounds like it maybe a problem. Moisture tends to get caught between two layers of vapor barrier.
Trade: siding
when did tar paper become a vapor barrier?
Tom |
I like Green things
Re: Vinyl Over Stucco Again |
Trade: Bricklayer
Maybe I am missing something. I'm not a carpenter nor do I claim to be. Why has tar paper been used under siding if it is not a vapor barrier? There are many books that list asphalt coated paper as a vapor barrier. What am I not understanding?
Trade: siding
actually its relatively vapor permeable,its the preferred house wrap of the Loneframer and many other craftsman on this site
![]() vapor barriers are of the poly sheeting type that are relatively impermeable to water vapor
Tom |
#9 | |
KemoSabe
Re: Vinyl Over Stucco AgainQuote:
Trade: Bricklayer
I do know that tyvek type materials are the preferred, better technology. Tar paper is an old way of wrapping a stick framed house. But in the situation the OP described do you think it would lead to rot?
Trade: siding
to me the only thing in that assembly that is a vapor barrier is the foam
Tom |
| The Following User Says Thank You to Tom Struble For This Useful Post: | NJ Brickie (08-16-2009) |
KemoSabe
I would be most concerned with the possibility of the chemicals in the paper having an adverse affect on the foam panels. I'm told that is why you won't see felt used with a Dri-Vit type system.
I agree with Tom that the foam would be more of a vapor barrier, unless it is perforated like fanfold. |
| The Following User Says Thank You to loneframer For This Useful Post: | NJ Brickie (08-16-2009) |
Trade: Bricklayer
Thanks for the info. Like they say you learn something new very day.
KemoSabe
Asphalt coated kraft paper, such as what is used in kraft backed insulation is a good vapor barrier because it doesn't expand in the presence of moisture, as felt paper will.
#15 | |
Trade: siding
thats for sure NJ, i have to rethink alot of the things i thought i was sure of after talking with the pro's here
Tom |
KemoSabe
| The Following User Says Thank You to loneframer For This Useful Post: | Tom Struble (08-16-2009) |
Trade: siding
your a nice man
Tom |
#18 |
Trade: Siding, Metal Roofs, and Beer Drinking PRO
I do viynl but I'd much rather have EIFS myself but thats just me.
I wouldnt suggest nails or glue for furring or the foam....screws are the better way to go. Use them 2' plastic eps washers on foam |
| 1 coat vs. 3 coat stucco finishing | janrickey | General Discussion | 12 | 07-17-2011 11:22 AM |
| Tile over vinyl pros and cons | tileguy7 | Ceramic & Stone Tile | 23 | 01-17-2009 09:53 PM |
| New stucco meeting up with old | MichaelNY | Masonry | 3 | 11-13-2008 07:25 AM |
| Painting vinyl siding | workpot | Painting & Finish Work | 18 | 11-06-2008 07:04 AM |
| Vinyl over stucco | Patrick | Windows, Siding and Doors | 25 | 03-25-2008 08:02 AM |
