Venting A Wood Stove With Other Things
Old 11-03-2008, 09:02 PM   #1
walshwoodworkin's Avatar
Trade: general const.
Hi,
I was wondering if you can vent a small wood stove into the same flue as the water heater. The stove has a 4" pipe and the water heater has a 3" pipe and the flue is a 9x9. There is the house heater attached to this also but it is only used rarely. The rest of the house is heated by pellet stoves.
any info would be helpful
thanks steve
walshwoodworkin is offline
Old 11-03-2008, 09:08 PM   #2
Home Serve's Avatar
Trade: siding windows soffit fascia
Re: Venting A Wood Stove With Other Things
Certainly not for a variety of reasons. Any wood burning appliance shall have it's own separate flue.
Missouri Remodeling Company with services for Replacement Windows Vinyl Siding and Entry Doors
Home Serve is offline
Old 11-03-2008, 09:13 PM   #3
Money Changer
bert0168's Avatar
Trade: Residential Remodeling
What kind of stove has a 4" flue?
I thought 6" was the min.
bert0168 is offline
Old 11-03-2008, 10:21 PM   #4
cleveman's Avatar
Trade: custom home building
I've seen it done before. The real question is, if the chimney has enough draw, can you use it as a central vac?
cleveman is offline
Old 11-05-2008, 06:11 AM   #5
Bigmo
Michael Olding's Avatar
Trade: Masonry Restoration and Repair
It certainly is against code to have two different fuels vented into the same flue... why not convert the water to electric?
Then the flue is free for the wood stove.
Michael Olding is offline
Old 11-05-2008, 06:20 AM   #6
DavidC
DavidC's Avatar
I agree with this but want to ask why? I may have known once but the reasoning escapes me now.
We have heated with wood most of my life and I can't imagine a 4" pipe on a wood stove. (6" min., I'll use 8")
And even if the other heater is only used rarely, it must be considered in the calculations as there is a possibility that at some point all 3 appliances will be trying to vent at the same time.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 11-05-2008, 07:23 AM   #7
Home Serve's Avatar
The main factor is that a woodburner needs an air tight flue to vent into without being diluted with air from another appliance hooked up to the same flue.
If in case of chimney fire it can pull other air in (thru HW heater or whatever) making it much worse.
The woodburner does not draw correctly without all air pulling thru it for proper combustion.
Old 11-05-2008, 09:17 AM   #8
DavidC
DavidC's Avatar
Thanks. All I remembered is don't, which has served me well so far.
Good Luck
DavidC is offline
Wood floors in an elevated bay house (Texas) Monarchy Flooring 22 01-30-2010 12:01 PM
Six stories in wood reveivl Framing 15 12-23-2008 11:37 PM
Simple (custom residential) wood cabinet spec ??? akm Finish Carpentry 4 08-28-2008 09:50 PM
wet-work and wood Rock Headed Masonry 10 08-28-2008 11:08 AM
