Vapor Barrier Question In Remodel. - Page 2 - Construction - Contractor Talk
Old 12-07-2011, 09:17 PM   #21
davitk's Avatar
Trade: Perfessional Contracter
Rewards Points: 502
Re: Vapor Barrier Question In Remodel.
I tend to see a lot of this. Homeowner says "fix the water stain on the drywall"...
Vapor barrier question in remodel.-dscn1811.jpg   Vapor barrier question in remodel.-dscn1813.jpg   Vapor barrier question in remodel.-dscn1814.jpg   Vapor barrier question in remodel.-dscn1818.jpg   Vapor barrier question in remodel.-dscn1821.jpg
davitk is offline
Old 12-07-2011, 10:21 PM   #22
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 218
No VB in a basement. Moisture will come in and won't have a way out.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is offline
Old 12-07-2011, 10:36 PM   #23
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,797
Interesting thought. How will it get in past the VB?
Tinstaafl is offline
Old 12-07-2011, 10:38 PM   #24
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
It won't. Migrates in via the foundation and gets trapped at the VB. Only place to go is into the studs or condense and drip down to the bottom plate. Of course, the bottom plate should be treated.
Angus
angus242 is offline
Old 12-07-2011, 10:47 PM   #25
Capra aegagrus
Tinstaafl's Avatar
Aye, there's the rub. In theory, the foundation and slab should be waterproofed/protected from such infiltration--IOW, have a vapor barrier on the outside.
In practice, there will be warm moist air inside the basement that WILL condense on those cooler masonry surfaces unless it's prevented from reaching them, by means of a VB.
Double VB.
Old 12-07-2011, 10:48 PM   #26
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
I run a dehumidifier in my basement 24/7 in the summer. 6 hours on/off in the winter. So much for theory
Angus
angus242 is offline
Old 12-07-2011, 10:54 PM   #27
Capra aegagrus
Tinstaafl's Avatar
I think we have plenty of evidence that yours is far from the theoretically perfect basement.
Old 12-07-2011, 10:55 PM   #28
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Ouch
Angus
angus242 is offline
Old 12-09-2011, 01:39 AM   #29
Fieldings's Avatar
Trade: Finish Carpentry/Renovations
This was caused by...?
Fieldings is offline
Old 12-09-2011, 01:49 AM   #30
Hair Splitter
Trade: General
Rewards Points: 218
What Angus said. But don't take my word on it:
http://www.buildingscience.com/resou...r_code_changes
Old 12-09-2011, 06:35 AM   #31
davitk's Avatar
Rewards Points: 502
Pure eeeeeeeeeeviiiiiil.
davitk is offline
Old 12-14-2011, 10:31 PM   #32
Fieldings's Avatar
You can't build a house in BC without putting VB on your basement exterior walls....
?? The code book where you are from really says not to use it?
Old 12-14-2011, 10:33 PM   #33
Fieldings's Avatar
Maybe you shouldn't use a VB if you Foundation isn't damproofed? Damproofing is code too obviously but , likely not from house built in the 70s....
Old 12-14-2011, 11:04 PM   #34
Fieldings's Avatar
No sill gasket?
Old 12-15-2011, 10:58 AM   #35
Hair Splitter
Trade: General
Rewards Points: 218
If the foundation is sealed and won't allow the transfer of moisture, then why do you need a VB on the interior wall?
Old 12-15-2011, 09:22 PM   #36
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
well lets see what else makes moisture in a house
Tom Struble is offline
Old 12-15-2011, 10:13 PM   #37
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 134
An interior vapor barrier is needed but it should not be attached to the framing - best method is attaching a dimpled drainage mat to the foundation (sealed at the top / sides & run long to the basement drainage system / weeping tiles, etc...) now you have a drainage plane & vapor barrier if installed properly
SLSTech is offline
Old 12-15-2011, 11:27 PM   #38
Hair Splitter
Trade: General
Rewards Points: 218
That would be the only way I would do it. That way any moisture would drain right into the drain tile system.
Old 12-15-2011, 11:32 PM   #39
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
I would gold leaf it first. We always gold lief everything.
ohiohomedoctor is offline
California Question!! MTN REMODEL LLC Electrical 10 11-20-2010 12:10 AM
Remodel Insulation Question brendanstl Remodeling 10 07-07-2010 07:39 PM
Code Question on Lamp wiring question ABLE1 NEC Discussion 8 06-16-2010 07:48 AM
Question on a fire remodel.. jmorton Remodeling 2 05-25-2010 06:38 AM
