Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Construction
Closed Thread
Old 05-22-2009, 08:02 PM   #1
Trade: Construction
Using pressure-treated wood for framing?
I work with my father, a professional home improvement contractor, and recently bought a house. We discovered termites and rot / water damage to one wall -- something that the inspector missed.
We opened up the wall today to understand the extent of the damage, and it extends from the sill plate (on the slab) up to a leaking window on the 2nd story.
We're selectively removing the damaged plywood and non-load-bearing 2x4 framing and replacing individual pieces one by one.
We replaced the piece of wood at the sill plate with a pressure-treated 2x4, as well as 3 studs. Since this is an area of moisture damage, we're going to continue using pressure-treated studs.
Is there a reason NOT to do this? I've done some Google searches, and it seems like pressure-treated wood is often recommended in areas of moisture or termite damage. My father thinks it's fine, but I like to get a wide range of opinions from other contractors, in case there's something in someone's experience that would point out reason for concern.
THANKS!
Scott99999 is offline
Old 05-22-2009, 08:07 PM   #2
Professiona Instigator
rbsremodeling's Avatar
Trade: Design Build Remodeling Contractor Washington, DC
THANKS!
What did your Dad say? are you Questioning your dads authority? shame on you
rbsremodeling is offline
Old 05-22-2009, 08:11 PM   #3
THANKS!
If you tell us what you
and your Dad really do,
we might tell you what the
problems are.....
Before we schuss you off
to the DIY site.
neolitic is offline
Old 05-22-2009, 08:18 PM   #4
Trade: Construction
He's a licensed contractor (and has been for 30+ years); I worked with him through college and since then, moonlight occasionally. It's fine to post this to the DIY forum, but....
It's not that I don't trust his judgement, but if you ask 30 people, sometimes you get 30 opinions and different experiences. For example - I wasn't sure if only certain types of pressure-treated lumber are suitable for framing, etc...
Old 05-22-2009, 08:22 PM   #5
Let's put it this way.....
I wouldn't pay for
your Dad's opinions
on this matter.
neolitic is offline
Old 05-22-2009, 08:33 PM   #6
Trade: Construction
Well, alrighty then...
Does anyone have some more helpful info? I don't see the point in attacking the poster (or for that matter, the source). My point was to solicit some more detailed professional opinions on why it would be prudent or not to use pressure-treated lumber for this repair, and as stated, if there's specific lumber that would need to be used (a certain dryness, etc...). I'm aware of the concern about the chemicals used to treat the lumber, but unsure of how much that matters when replacing a few studs in an area at risk for water damage.
Old 05-22-2009, 09:15 PM   #7
knucklehead's Avatar
Trade: Framing,Remodeling,General Contractor
He probbly did it cause it was all he had to work with.
knucklehead is offline
Old 05-22-2009, 09:17 PM   #8
Trailer park boy
shanekw1's Avatar
Why not keep the water out by fixing the leaking window?
Then there's no worries about water damage.
"Industry without art is brutality"
shanekw1 is offline
Old 05-22-2009, 09:23 PM   #9
genecarp's Avatar
Makes no sense
genecarp is online now
Old 05-22-2009, 09:26 PM   #10
Trade: Remodeling / Carpentry
There are several reasons not to use PT as wall studs as you describe. PT twists, bows and bends upon drying. This effect can also lead to literally spitting out screws or nails of a drywall installation.
Fix the water infiltration first. Then repair with regular lumber. Use PT where recommended, in damp areas, plates, infestations as you said.
Addl - Scott - edit your profile to receive private messages. I can send some addl info.
We Fix Houses is online now
Old 05-23-2009, 08:11 AM   #11
Administrator
Nathan's Avatar
Trade: Painting Contractor
Send a message via AIM to Nathan
Please post your question at www.DIYChatroom.com. This site is for professional contractors only.
Thanks.
Nathan
"He is no fool who gives what he cannot keep to gain that which he cannot lose." - Jim Elliot
Nathan is offline
Closed Thread
White treated SYP casey344 Decks & Fencing 14 01-30-2009 10:33 PM
Covered Patio 10 x 10 - Should I wood block? gussy1971 Roofing 1 01-27-2009 06:19 PM
pressure treated wood question???? davinci Construction 19 08-30-2008 12:00 PM
Aluminum Coil On Pressure Treated oldfrt General Discussion 14 11-08-2007 07:55 PM
Pressure Treated Wood rjordan392 Carpentry 4 05-28-2007 01:23 PM
