Using Marble, Granite On Walls Construction
Old 10-08-2006, 03:58 AM   #1
p3rsian's Avatar
Trade: none
Hi there,
Im having issues with a property , The problems are this property is 20 levels and from the bottom to the top there is huge granite , marbel stones in big dimensions on top of each other, after 2 - 3 years because of the weight of these stones on top of each other there is a slight slope and its not straight anymore. I was told there is a way to make a graving on the back of the stone so it would fit into a holding which will be installed in the wall so it would not move after years go by.
my question is that what is the machine called that puts a graving sort of like a hole on the back of the stone ?
p3rsian is offline
Old 10-08-2006, 11:39 AM   #2
Moderator
Double-A's Avatar
Re: Using Marble, Granite On Walls Construction
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
New York Times, July 20, 2006
Double-A is offline
My fault or the granite guy's? john elliott General Discussion 86 01-17-2011 03:48 AM
I want to get in Construction and am looking for advice chompchomp12 Business 21 12-17-2009 10:39 PM
fixing marble to walls murf Ceramic & Stone Tile 4 09-27-2006 12:05 AM
Bridging for above grade Concrete Walls ETHICS05 Construction 1 11-21-2005 12:43 PM
