Traditional Cut Roof
Old 07-06-2008, 06:49 AM   #1
Loqueris's Avatar
Trade: Roofing / Building
Can anyone advise on a traditional cut roof in the uk please.
We intend to use 47mm x 195mm grade C16 wood at 600mm centres.
Does anyone have access to BS5268-3 Regs and can advise on the current specs for connection, nails, bolts etc etc? Or a decent website offering advice.
Loqueris is offline
Old 07-06-2008, 06:59 AM   #2
Handle It!
MALCO.New.York's Avatar
Re: Traditional Cut Roof
A "Roofer", as you state you are, should be self-sufficient concerning this application. Are you sure you are a Roofer?
Ultimate Wisdom---------
MALCO.New.York is online now
Old 07-06-2008, 09:53 AM   #3
billy d's Avatar
Trade: carpenter
Hi Loqurris my advice to you would be to stick a feather in your head because all the cowboys are getting sacked.BTW welcome to the site.
billy d is offline
Old 07-06-2008, 12:20 PM   #4
I used to think so.......
wallmaxx's Avatar
http://www.tra.org.uk/pdf_files/pds4.pdf
http://www.timberframe.co.uk/forms/TRA%20Attic%20Bracing.pdf
47mm = 1 7/8"
195mm = 7 11/16"
600mm = 23 5/8" o.c.
Check your span charts and prints....then, as we say over here,
"Git er done."
wallmaxx is offline
Old 07-06-2008, 08:54 PM   #5
1018's Avatar
Originally Posted by wallmaxx View Post
Is the lumber milled differently over there, or is that just from the metric to imperial conversion?
1018 is offline
Old 07-09-2008, 04:33 PM   #6
billy d's Avatar
Trade: carpenter
That was a good post Max but I think Malco called it right.The OP was either
a HO or a hack.In the UK a hack is known as a cowboy so if the OP is from the UK he new exactly what I was saying to him.
I just hope its his roof he's making a mess of and not somebody else's.
billy d is offline
Roof Estimating And Drawing Program Ed the Roofer Roofing 32 03-07-2011 10:50 AM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Help tying in this roof to addition jaymay75 Framing 0 06-18-2006 10:54 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
