Trade: general contractor
Tin Roof Sweat?
I am getting ready to put tin on a sun room roof {rafter and perlins}it will be insulated inside with fiberglass batts directly in the rafters{no air space}can anyone tell me if condensation on the bottom side of the tin will be a concern,as I have seen uninsulated tin sweat underneath in the mornings when the sun hits it. What if anything would you recomend I put under it and would it be a problem creating a double vapor barrier.{with the fiberglass barrier inside}.Thanks for any advice!
Re: Tin Roof Sweat?
Short answer: No, we do this all the time and I install metal roofs on new construction homes with no adverse problems.
Trade: Framing
Re: Tin Roof Sweat?
I was wondering the same thing........for our building.....but, we've got a tin roof......and will have the insulation blown in(sitting on top of the ceiling so to speak)......so will the condensation hurt me any, if so.....what to fix it with???
Re: Tin Roof Sweat?
If the space above the ceiling has ventilation, you are ok. On new homes, I roll insulation over the purlins, lay metal over, and still insulate the ceiling. The real benifit to doing this is in the summer.
| Low Pitch Roof solutions | Fixer | Roofing | 4 | 02-18-2007 11:09 AM |
| Help tying in this roof to addition | jaymay75 | Framing | 0 | 06-18-2006 10:54 PM |
| Need help designing Roof for addition | jaymay75 | Framing | 21 | 06-17-2006 10:47 PM |
| Torch down(flat roof) leaks BAD...can you give advice ASAP? | Detail Guy | Roofing | 21 | 01-16-2006 02:36 PM |
| Do You Need A New Roof ??? | Perfect Roofing | Roofing | 0 | 02-10-2005 02:46 AM |
