Trade: Designer Renovator
Thin Slab On Top Of Existing?
I have a basement, slab on grade. The concrete is without cracks, but it's old and has dips and discoloration. I'm turning the basement into living space and want an acid stained color with a high gloss finish. I know elitecrete and those other decorative concrete companies say they require a fresh floor as underlayment for their product. They tell me to grind down my existing floor, but that would require a lot of work. Could I just pour a thin layer of lightweight concrete on top of my existing? If so, how thin is too thin? Would I need to grind the new one, too?
Emily |
Re: Thin Slab On Top Of Existing?
In addition,
Has anyone heard of or used Patchcrete? According to Artcrete's distributor, I could trowel this bonding agent to my existing concrete, then stain and seal that. I'm skeptical that it will flake off. |
#3 | |
Trade: MASONRY CLEANING/ CONCRETE SURFACE PREP
Re: Thin Slab On Top Of Existing?Quote:
JIM CARROLL INLET PRESSURE CLEANING MYRTLE BEACH SC |
Trade: Mold Remediator, Decorative Concrete, Bamboo Fencing,
You can put an overlayment over the top of the old slab. First you would have to fix all the dips and discoloration. Then apply the overlay. Sand it down. Acid stain and seal.
The way I would do it is grind , fix dips and discoloration because that can bleed through to the top of your overlay. Cement overlay on top. Acid stain color. Saw cut if wanted then seal it.
IAQM
www.iaqm.com Elite Concrete Finishing www.eliteconcretefinishing.com Elite Bamboo Products www.elitebambooproducts.com |
| Help Installing Hardwood over old/new Concrete Slab | Hages | Flooring | 7 | 06-04-2008 01:02 PM |
| built up slab question | stampcrete | Concrete & Paving | 9 | 03-27-2008 05:24 PM |
| Demo a foundation under a radiant heat slab without disturbing the slab...? | wackman | Remodeling | 18 | 04-02-2007 12:38 AM |
| Slab not square? | irving | General Discussion | 15 | 01-10-2007 12:36 AM |
| How to measure and add foundation to an existing home. | ISH | Masonry | 12 | 11-09-2005 08:25 PM |
