Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Construction
Old 09-14-2009, 05:31 PM   #1
Thin layer of concrete
Hello
New to the forum and glad to have found it. I have a question about concrete. I have a customer that wants to frame in an existing covered patio to create a closet. The existing slab however is about 1.5" lower than the house's slab. What is the best method for creating the same level between the two? I haven't done much work with concrete and I'm concerned and need some help. Certain type of concrete? What type of reinforcement, if any? Bonding agent? Thanks for any advice.
John
jtcamp is online now   Reply With Quote
Old 09-14-2009, 05:55 PM   #2
General Contractor
Willie T's Avatar
Even your local HD carries the thin concrete and bonding agent. The stuff they have is good for as thin as 3/4"... Better places carry some that will go on as thin a s 1/2". The HD stuff is about $15 a bag. A one car garage at 1.5" will cost you at least $2,000.
"True eloquence consists in saying all that is necessary, and only that which is."
François Duc de La Rochefoucauld
Bill Everett - St. Petersburg, FL
Willie T is offline   Reply With Quote
Old 09-14-2009, 05:58 PM   #3
Illusion of Perfection
CookeCarpentry's Avatar
Trade: Residential Remodeler/Custom Carpenter
What about a P/T sleeper system with plywood?
Mark
Wayne, PA
"It is what it is."
CookeCarpentry is offline   Reply With Quote
Old 09-14-2009, 06:41 PM   #4
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
What's the final flooring going to be?
Mapei makes products designed for doing this that can go from feather edge to 4".
Here are their floor leveler products, best way to figure out what you need is to start with what the finished flooring will be.
http://www.mapei.us/
Mike Finley is offline   Reply With Quote
Old 09-14-2009, 07:49 PM   #5
the size of the floor may move you in one direction or the other. the floor leveler for a large area could get expensive. your location is also important and try to describe conditions such as moisture in the area.
72chevy4x4 is offline   Reply With Quote
Old 09-15-2009, 12:00 AM   #6
Thanks for the responses so far.
The area is 70 sq ft and the finished floor will be carpet. The patio exists at the highest elevation on the property, so moisture is running away from it. Am I wrong in thinking that the two floors need to be at the same height?
I apologize, but I am new to some of this. For the last few years I have always worked along side of a professional and this most recent job is now in my hands. Thanks for all the help.
John
Old 09-15-2009, 06:32 AM   #7
You will have to deal with ground moisture migrating up through the slab and also your wall plates need to be 8" above grade.
TimNJ is offline   Reply With Quote
Old 09-15-2009, 09:20 AM   #8
Chief Toilet Mover
John
Gone to Mapei's website yet or still f'ing around?
Apply one of the Planiseal versions (you will at least have to contribute enough to the solution to figure out which one you need) - Planiseal will eliminate the moisture migration issues in the concrete.
Frame it with double bottom plates made from PT.
Look at Ultratop which will level up to 2", and level the floor to the height of the existing floor.
After that is it going to be glue down or stretched carpet?
Old 09-15-2009, 12:00 PM   #9
Thank you both.
Mike-
Going to the website now...got the hint.
I was thinking of gluing down the carpet but open to suggestions.
John
Concrete Company delivered junk concrete. How best to pursue? marcomjl Concrete & Paving 39 09-19-2009 09:08 AM
4x4 posts in concrete vs. saddles Strongarm Decks & Fencing 20 08-31-2009 09:41 PM
Thin Brick over Painted Concrete Tommy C Masonry 5 08-27-2009 07:33 AM
Thin Brick Underlayment Cache Masonry 5 10-07-2008 08:58 AM
cement wash or concrete rub a thin layer over brick pavers brownstone89 Masonry 14 08-25-2008 06:14 PM
