#21 | |
Restoration Crazy
Re: Temporary HeatQuote:
Got a link?
Jason E Whipple, General Manager Historic House Restoration, Cincinnati, Ohio Facebook | Twitter |
#22 |
Trade: heavy construction
Re: Temporary Heat
On large open areas where an open flame is a problem we use a oil fired hot air furnace. Run some temp duct work where you need it, the furnace & oil tank can be kept outside. If you don't want to use oil a gas furnace works equally as well.
#23 | |
Trade: General Commercial Construction
I used them in both insulated and non-insulated buildings. The last place was 6000sqft. Propane was the fuel I was using but it will work on natural gas also. It uses 16lbs of propane an hr when running fullblast 350,000btu's. Sorry about not being able to post the link |
#24 |
Trade: Building
Re: Temporary Heat
brrr its chilly this morning, could do with a heater.!!!
#25 |
General Contracting
Trade: Real Estate Broker, Property Manager
Re: Temporary Heat
Yes, it was a chilly start. Yesterday morning caught me by surprise. I didn't put the wood stove on so temps dipped way down over night inside.
Hey, do they require Fire Suppression systems in these barns. I have heard a number of areas are now requiring it. Not sure why anyone would not want it. I saw two barns burn up. Both contained very expensive race horses. Most did not make it. |
| Radiant Barrier Fact Sheet | Ed the Roofer | Roofing | 0 | 02-09-2008 08:57 PM |
| Heat Exchanger Problem with Hayward Pool Heater | jtc1062 | Pool Construction & Enclosures | 6 | 10-24-2007 10:33 PM |
| Heat Exchanger Problem with Hayward Pool Heater | jtc1062 | HVAC | 2 | 10-22-2007 10:13 PM |
| heat pump help!?!!! | maxkd | HVAC | 1 | 11-10-2006 08:57 PM |
| Heat Exchanger Inspection Methods | MechAcc | HVAC | 3 | 04-14-2005 04:38 PM |
