Get the board stretcher!
Trade: Residential Building and Remodeling
Tapcons Or Power Actuated
Recommendations for fastening 1 1/2" foam basement wall system with furring strips. To finish with MR drywall. I'm currently using 2 3/4" Phillips head Tapcons with hammer drill and corded driver, and am in need of more Aleve!
Does anyone have a preference any why? Is there a difference in a vertical application?, holding power? Should I just suck it up and finish?
"...You cannot strengthen the weak by weakening the strong..." Abraham Lincoln |
Re: Tapcons Or Power Actuated
I'd keep doing it your way. Ramsets can create cracking and there is no control over them. Hit a couple of hard pieces of aggragate and you have a nail head to contend with, don't hit any at all and it goes right through the strip.
#3 | |
Re: Tapcons Or Power ActuatedQuote:
I feel tapcons are the best way. Power actuated fasteners can cause cracking and will easily work loose in time, - - especially on a vertical application. Are you pre-drilling holes in the wood that are slightly larger than the screw shanks?? Countersinking for the heads?? Running construction adhesive to allow for less screws?? 'Setting' the tapcons only 3/4" or 1" into the wall?? Are you aware M-R drywall has been deemed ineffective/unnecessary?? |
You might try these.
http://www.confast.com/products/split-drive-anchor.aspx It would be a little faster than the Tapcons Or what I do with the ramset nails is simply drive em in with a hammer, you don't need the gun on most applications. The nails are very hard and if you can hit strait they go in like butter. But like stated earlier they can come loose or a big stone can deflect it. |
Chief Toilet Mover
Trade: Bathroom Remodeling
If you are looking for every advantage, I'd ditch the philip heads and get yourself the hex headed versions and put them in with an impact driver.
Moderator
Ugh! Tom'r and Mike have this calf licked. Take their advice.
Deck Designer/Builder
Re: Tapcons Or Power Actuated |
#8 | |
Yes. Yes. Yes. Behind foam not furring strips. Yes. 1 1/4"And even that is getting to be a handfull. No. Is that correct? How do you figure? (of course I'm getting $.60 more per sheet with MR...OH HOLD ON I dropped a penny..)
#9 | |
The tapcons only need to 'penetrate' 3/4 of an inch, - - sometimes you need to penetrate 1", only because of the screw-length increments, - - any deeper is just wasted energy.
P.S. Mike makes an excellent point about the hex-heads that I failed to mention . . . |
Builder, Remodeler
Trade: Builder, Remodeling Contractor
Sometimes, you can use a square-drive with the #3 phillips bits, or one of the hybrids that is basically a square drive with phillips blades on the corners.
DEFINITELY use an impact driver, regardless of which bit. Be careful not to over drive them. Hex heads are the way to go, if possible. An SDS hammer drill definitely goes a lot faster for drilling the concrete. Best wishes on the project. -TH |
sheeter
Trade: architectural metal panel systems, curtainwall
TomR is wrong. The recommended minimum embedment for Tapcon screws is 1". Your doing right by sinking them 1-1/4" or more. Mike Finley is right, scrap the phillips head and get the hex head screws. But with hex had screws, you wil need one slightly longer and use a driver gun with more torque. If you use a Dewalt Tek gun, I would recommend the DW257, life will be easier. I use tapcons on a daily basis and this is what I have learned.
I'd stick with the tapcons. even though they are slower to install, they will give a better job on the furring strips than powder actuated.Some of your agony may be caused by the tool you are using. Are you using a "Hammer drill" as you said or a "Rotary hammer". A small rotary hammer like one of the Bosch Bulldogs or similiar will make quick work of drilling compared to a hammer drill. Also when the bit becomes worn, throw it away before it starts to drift in the hole, because the diameter of the hole is important for the success of the tapcons.
Trade: Renovations
"Agreed!
The Phillips head screw should have NEVER been invented!" You must be from Canada!!! I can't believe that all the 'manufacrured' stuff you get from the States still comes with philips head screws. The man who invented them must have had three hands: one to hold the work, one to hold the screw on the driver and one to hold the tool. Long live Robertson! (Square drive for most of you guys). (and hex and torx and almost anything except slot and philips (what else is there))
Trade: i am a small remodeling contractor been at this most my life
No he isnt wrong ive used tapcons for years at 3/4" to 1" deep never had a problem ..your just making more work and headaches going deeper....and yes on the hex heads..
#15 | |
At the same time, - - I'd be willing to bet money that they used to say they wanted 3/4". Either way, - - good call, sheeter . . .
http://www.tr-built.com Last edited by Tom R; 10-03-2006 at 06:24 PM. Reason: rare spelling error - - heh-heh |
reveivl, the one that you missed is the compound head, some manufacturers us them. They are supposed to take a slot, Phillips or sq. drive. They kinda work with the sq. drive, kinda not with the others.
#17 | |
Moderator
| power trowel | banctecbobn | Construction | 4 | 09-02-2008 01:54 AM |
| Solar Power Industry Dead In California | w6ire | Electrical | 2 | 06-28-2007 09:57 AM |
| Selling excess Power | robertc65 | Electrical | 27 | 06-14-2007 10:16 AM |
| Power Outage Question? | Ron The Plumber | HVAC | 5 | 12-20-2006 09:42 AM |
| Water heater, elec., power surge problem ??? | tzzzz216 | Plumbing | 8 | 11-05-2006 10:24 PM |
