Suggestion For Installing Insulation In Floor Joists
Old 11-03-2008, 06:08 PM   #1
72chevy4x4's Avatar
I'm working with 4" wide trusses 24" OC and need to come up with a method to hold up insulation. The typical metal hangers are too wide (they're made for a 2" piece of lumber). considering using a pnuematic stapler and installing 3 pieces of metal hanger / 4' batt or a roll of wire pulled through many trusses, stapled. Netting was the original choice, but it's not working well enough-too much sag.
Any bright ideas out there
72chevy4x4 is offline
Old 11-03-2008, 06:47 PM   #2
Home Serve's Avatar
Trade: siding windows soffit fascia
Re: Suggestion For Installing Insulation In Floor Joists
I'd just cut the wire insulation wires to the proper length or find some other wire and cut it to length. The wires work well and are easy.
Otherwise I've seen folks use string and staple the string to the trusses. I have never done it that way but you'd have to find string made of a material that does not stretch.
Missouri Remodeling Company with services for Replacement Windows Vinyl Siding and Entry Doors
Home Serve is offline
Old 11-03-2008, 07:06 PM   #3
Dan_Watson's Avatar
Exactly what he said .
Dan_Watson is offline
Old 11-03-2008, 07:14 PM   #4
Blockade's Avatar
Trade: worker
String and a hand stapler! Put the insulation in place and staple a knotted string to the bottom, side or middle of the joist. You can use a ball of string and just keep unrolling it as required in a zig-zag...works great in crawl spaces and can be put right onto the bottom of the joist if you are drywalling or sheathing it....
Blockade is offline
Old 11-03-2008, 07:28 PM   #5
72chevy4x4's Avatar
do you think the string would work well w/ 21" spacing? I'm wondering about the sag factor. I'll bring in the chopsaw and cut down my metal rods to see how they stay up.
Old 11-03-2008, 07:39 PM   #6
Remodeler Extraordinare
A.W.Davis's Avatar
You ever considered subfloor insulation netting??
http://www.jrproductsinc.com/shop/pc...idCategory=117
Edit: nevermind I didnt see that you already tried netting
A.W. Davis Construction Co.
http://www.awdavisconstruction.com/
Your friendly remodeling contractor
A.W.Davis is offline
Old 11-03-2008, 08:24 PM   #7
Sean
SLSTech's Avatar
Out of the box thought for you - rigid insulation cut just a fraction to large & place it in thereto hold the fiberglass up
SLSTech is offline
Old 11-03-2008, 08:25 PM   #8
DavidC
DavidC's Avatar
Never heard of that string idea, sounds pretty simple and effective. Here in the backwoods we use chicken wire stapled to the bottom of the joists.
I hope I remember the ball of string if I ever have to do it again.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 11-03-2008, 08:28 PM   #9
Blockade's Avatar
Trade: worker
It works tried and true. R40 on TJI and and on lots of other standard joisting. You can space the string as close or as far apart as you need too. It is a one man operation or have someone follow behind and nothing to go wrong. If the string tangles, cut it and restart. If you need to protect the insulation then that is another story, but just to keep it there....string.
Blockade is offline
Old 11-04-2008, 03:28 AM   #10
Stewy's Avatar
Trade: home improvements and renovations
Have used strips of poly stapled to the bottom of the framing.
Stewy is offline
Old 11-04-2008, 06:44 AM   #11
72chevy4x4's Avatar
If string, would you use a nylon string? I'm wondering if twine, in a moist crawlspace, may eventually rot.
Old 11-04-2008, 06:54 AM   #12
Handle It!
MALCO.New.York's Avatar
Simple!
Polypropylene! "Strapex".
Ultimate Wisdom---------
MALCO.New.York is online now
Old 11-06-2008, 06:20 PM   #13
ALL VINYL
all vinyl's Avatar
Trade: VINYL SIDING CARPENTRY
WOOD LATH AND GUN . BUT I LIKE THJE CHIKEN WIRE
all vinyl is offline
Old 11-07-2008, 07:18 AM   #14
Professional Remodeler
firemike's Avatar
I have gone the chicken wire route, extra work and money, but looked good. The last one I did I took the boxes of wire insulation supports and cut them to length with a small hand grinder with a 4 1/2" metal-cutting blade, cutting the whole bax of wire at once. Quick and worked like a charm.
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
Old 11-07-2008, 08:35 AM   #15
Restoration Crazy
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Send a message via Skype™ to Jason Whipple
With the cost of fiberglass insulation up so much, the extra cost of strapping, and the time involved to all that; you would be far better off to spray foam it.
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
The Following User Says Thank You to Jason Whipple For This Useful Post:
Dirtywhiteboy (09-24-2011)
Old 09-24-2011, 11:39 AM   #16
72chevy4x4's Avatar
have some more work to do in this field and have recently inspected the first job...used nylon twine (large rolls meant for a hay bailer) and cap nails on the ends for strength to pull the twine tight and stapled in the field (middle). The method is absolutely spotless-NO insulation has fallen and it stays put even with drain leaks above (pipe leaks).
After the first few jobs I switched to using metal wire hangers because the job required costs to be cut...cut the 22.5" metal down to the appropriate width. The cut end doesn't have the taper like it does from the factory which helps it dig into the wood. This problem was alleviated by digging the wire in a little bit during the installation method. The upcoming jobs I'll cut in mass and roll them across the grinder wheel to put a slight point on the hangers.
as an FYI: after inspecting crawlspace jobs which I did not do and that may be 4-6 years old, they used mason's string to hold the insulation up-the string stretches and is too small for the task or fallen-50% failure rate in those spaces (fallen insulation). I feel like I"m a pro at this job now!
Old 09-24-2011, 01:24 PM   #17
Construction Philosopher
A.T.C.'s Avatar
Trade: Builder
Thanks for the info on the masons twine. I was wondering about that.
I've used rebar pliers to cut the wire rods down before, and it puts a nice, sharp point on the end. Might be too time consuming for a big project, though, I don't know. But then again, cutting them with a chop saw and shaping with an angle grinder might take the same time.
A little Learning is a dang'rous Thing;
Drink deep, or taste not the Pierian Spring:
There shallow Draughts intoxicate the Brain,
And drinking largely sobers us again. -Alexander Pope
A.T.C. is offline
Old 09-25-2011, 05:23 AM   #18
Handle It!
Can one say... "HOLY old?"
insulation types for new buildings sprayseal General Discussion 14 10-12-2009 07:14 AM
Radiant vs rigid insulation or BOTH how much of each wolftrap Insulation 3 08-29-2008 03:34 PM
Exterior patch over insulation plugs Chris B Painting & Finish Work 2 08-25-2008 03:33 PM
Radiant Barrier Fact Sheet Ed the Roofer Roofing 0 02-09-2008 08:57 PM
Interesting attic insulation findings IHI General Discussion 5 02-28-2006 02:22 PM
