Steel Plate Connection
Old 02-10-2018, 09:30 AM   #1
npe1082's Avatar
Trade: MEP
Rewards Points: 28
Hi All,
Please see attached image. Which type of connector should be used to connect this steel plate to 12 x 12? Treated wood layer underneath.
Expansion Bolt vs. Lag Bolt vs. Carriage Bolt vs. Through bolt vs. something Exposed
npe1082 is offline
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task!
Old 02-10-2018, 11:04 AM   #2
Bubble stick operator
Defenestrate's Avatar
Rewards Points: 184
Re: Steel Plate Connection
Your drawing came through as a thumbnail, so totally useless.
Your architect/engineer should be able to answer this question and be compliant with local codes.
If you are your own designer, talk to your AHJ.
ps, most people use the introductions section to demonstrate that they are working professionals...
Defenestrate is offline
Unscrewed/unnailed bottom wall plate MikeJSchorah Framing 13 02-27-2017 05:26 AM
Steel Tubing Lintel Strength 6stringmason Masonry 16 10-04-2012 09:12 PM
3/16" 1x19 stainless steel cable lukehatfield Contractor Swap 0 09-14-2012 10:06 AM
24' x 45' Patio with 4 Steel Post Only buddyb1201 Remodeling 11 08-10-2012 12:14 AM
stocking service trucks MO-AMPS Electrical 23 11-25-2009 09:39 PM
At we cater exlusivly to professional contractors who make their living as a contractor. Knowing that many homeowners and DIYers are looking for a community to call home, we've created DIY Chatroom is full of helpful advices and perfect for DIY homeowners.
