Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Construction
Old 10-03-2006, 09:12 PM   #1
Dumb Laborer
Trade: Union Laborer; Heavy & Highway Construction
Steel I beam capacity
Trying to find a site that can tell me the load capacity of a steel I beam . Does anyone know of a site that does this? So far I havent been able to find one. Thanks in advance..
IHdonnie is offline   Reply With Quote
Old 10-03-2006, 09:36 PM   #2
ch0mpie's Avatar
Trade: Geotechnical PE
don't know of a site, but what is your load and span? Or beam and span? I can scan the page from the LRFD manual.
ch0mpie is offline   Reply With Quote
Old 10-03-2006, 11:50 PM   #3
Get your beam properties here-
http://efunda.com/math/areas/IbeamIndex.cfm
Then calc here-
http://efunda.com/formulae/solid_mec..._bc_simple.cfm
Dustball is offline   Reply With Quote
Old 10-04-2006, 04:45 PM   #4
tgeb's Avatar
Great site Dustball.
www.gebcon.com
tgeb is offline   Reply With Quote
Old 10-04-2006, 07:13 PM   #5
K2
K2's Avatar
Yes, no more bs.
K2 is offline   Reply With Quote
Old 10-04-2006, 09:19 PM   #6
Dumb Laborer
That would be great, thanks.
Old 10-04-2006, 09:19 PM   #7
Dumb Laborer
Originally Posted by Dustball View Post
That's a handy site, thanks for the link.
Old 10-05-2006, 03:53 PM   #8
ch0mpie's Avatar
donnie,
The manual of steel construction has tons of pages of charts, I'm not going to take the time to scan all of them It there is a specific one you need I would be happy to though.
I would use that website carefully, maybe I missed something, but it does not tell you the max ALLOWABLE stress on the beam, it only tells you the actual stresses on the beam. From what I can tell, you can type in a beam with a span and loading that will fail and it will just give you output. Unless you know how to calculate the allowable stress, and compare these to the output, this website seems useless and even dangerous. Also, I don't think it checks for localized failures.
Old 10-08-2006, 12:32 AM   #9
Dumb Laborer
donnie,
Yeah, that's what I'm thinking. Got a "homemade" bridge going to a house. 8" tall I beam on either side, spanning about 20'. Has wood decking on it. If you can find a page that has something close to this listed and could scan it, I would appreciate it.
Old 10-08-2006, 12:22 PM   #10
ch0mpie's Avatar
Beam sizes that small are not represented on the referance tables. They have to be anylized by hand. I suggest that you consult an engineer.
Old 10-10-2006, 12:41 PM   #11
Trade: i don't understand what you are looking for
what kind of title are you looking for
I don't understand why the faces ect. I just wanted to offer an answer not play around.
Here is a link in reposnse to the question but I don't know if this system will accept it. Too much monkey business!
http://www.toolbase.org/Design-Const...am-column-load
dieterschmied is offline   Reply With Quote
Old 10-10-2006, 03:06 PM   #12
ch0mpie's Avatar
I'm not sure what your talking about; however, that manual of steel construction specifically for residential construction is an excellent resourse.
Old 10-20-2006, 06:48 PM   #13
Joshua's Avatar
Trade: Truss Plant Gen Mgr
What type of traffic?
Joshua is offline   Reply With Quote
Old 10-21-2006, 08:42 PM   #14
Trade: General/ Frameing/ Concrete
On 2 projects I've done with just floor load bearing and a span of 20' a 8" I beam was more then enough spec'd by an engineer. The steel supply you get the beams from usually will calculate the loads and sizes for you at no charge.
csol is offline   Reply With Quote
Beam Specs ophnurse Framing 19 10-02-2007 07:21 AM
flitch beam installation kweber General Discussion 4 02-04-2007 11:43 AM
deck beam sizing and post spacing? diyerforever Decks & Fencing 5 05-10-2006 09:58 PM
ideas for wood stud wall attachment to steel "I" beam? durham Construction 9 05-10-2006 05:45 PM
Can I replace a W8x35 x 20 foot steel I beam with... Ray General Discussion 8 03-20-2006 03:38 AM
Contractor Talk™ © 2003 - 2010 The Building Network LLC
