Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Construction
Old 04-30-2009, 07:16 PM   #1
Steel Framing Fasteners
I do a fair amount of steel framing, always used an impact driver. and self drilling zips, although I recently switched to self drilling wafer head screws.
Recently someone asked my why there wasn't a riveting system for installing them. So I did some research and actually found some articles on framing riveters. but I have been unable to find any for sale or find out who makes them... Any info there would be great. Also I found the versapin nailer that seems like a dream but as I looked closer at the site seems all they make is for 18g and thicker... I frame with 20g Interior mostly.... I do very little exterior steel framing, so not really worth buying the setup for it...
So questions are ...
Whats the fastest setup you know of for steel framing 20g... riveter, nailgun?..
Orca is offline   Reply With Quote
Old 04-30-2009, 08:21 PM   #2
Coming out of the closet
ClosetPro's Avatar
Trade: Closet Design-Install-Remodel
Paslode has/had a coil nailer for that exact use. The nails had special rings grooved into them to hold tight. Check it out.
Edit.... The nailer I was thinking of is designed for wood to metal framing.
Last edited by ClosetPro; 04-30-2009 at 08:48 PM. Reason: Fact checking my post....I was wrong.
ClosetPro is offline   Reply With Quote
The Following User Says Thank You to ClosetPro For This Useful Post:
Orca (05-01-2009)
Old 04-30-2009, 08:45 PM   #3
Trade: Union Carpenter
is screwing them with a button really that slow that you need to look for something faster?
Boycer88 is offline   Reply With Quote
Old 04-30-2009, 10:38 PM   #4
TracyMC
Trade: Commercial Construction management, Project Manage
Look into the TecPin fastening systen from ITW Ramset, or the systen fron MAXX. They both have pneumatic fasteners or gas fasteners like a Paslode that have ICBO ratings to macth up with the fastener.
Trace
TracyMC is offline   Reply With Quote
The Following User Says Thank You to TracyMC For This Useful Post:
Orca (05-01-2009)
Old 04-30-2009, 10:43 PM   #5
TracyMC
Hey, I did'nt answer the question. the above are great systems, but not a hell ua lot faster than, a screwgun and K- Lath screws, if that is not fast enuf look @ the Grabber Super Drive it has all of the ICBO"s and easy to get. If you are lucky the vendors in your area will have the TF1100 and TePins, but really only good for 30-33 mil studs or heavier
Orca (05-01-2009)
Old 05-01-2009, 12:16 AM   #6
Trade: waterproofing
Cool
As with any DIY home improvement, a few hints or tips can go a long way towards making the project a roaring success. Building a steel shed starts just as any other building project would. Steel sheds are built from the bottom up. In this case, the bottom meaning the pad or foundation. Pouring a concrete slab is a bit too strenuous a job for most homeowners. It is recommended that you hire a masonry contractor for this part of your building endeavor. Still, there are a few things you will want to do in this phase, in order to make the actual assembly of your steel shed go more smoothly.
Barkri12 is offline   Reply With Quote
Old 05-01-2009, 12:35 AM   #7
ClosetPro's Avatar
Dude, are you fluent in english? Your reply is from outer space, (sorry man gotta call them as I see them). NO WHERE did ANYONE say anything about "DIY" - "steel sheds" - or all the other babble you posted. Are you sure you are in the right forum?
hughjazz (05-01-2009)
Old 05-01-2009, 12:47 AM   #8
Bunny by Malco - NY
Chris Johnson's Avatar
Trade: ICF Construction
Use Grabber #10x3/4" with LOX tips, I find them the best and fastest
Chris
Chris Johnson is offline   Reply With Quote
The Following User Says Thank You to Chris Johnson For This Useful Post:
Orca (05-01-2009)
Old 05-04-2009, 08:34 PM   #9
Trade: Construction management/General contractor
ive always just used 1/2" self tapping panheads.
we recently got a pamphlet on a nailer for steel framing. but never seen one in action
Blackcloud is offline   Reply With Quote
Old 05-04-2009, 11:54 PM   #10
Trade: Control Systems
I'm not expert on the subject but what about stud crimpers? I've seen a few guys use em and they look pretty slick.
Inner10 is offline   Reply With Quote
Old 05-05-2009, 12:06 AM   #11
Bunny by Malco - NY
Yea, they work really good on drywall studs...try that on structural framing studs and it's a no go.
Other thing to laugh at is when the mechanicals are run all the studs fall out
Chris
Old 05-05-2009, 04:19 PM   #12
Ahh makes sense; I've only seen em on residential sites, basement reno's. On commercial sites all I see are sharp point K-laths and self-tapping waffer-heads.
Old 05-23-2009, 07:25 AM   #13
Trade: carpenter/ handyman
Closetpro,
Barkri12 tucked tail & ran on this one didn't he? Some one must have slipped something in his coffee that day?
Steve
stp57 is offline   Reply With Quote
how do you estimate steel stud framing? Wensdy Framing 8 07-21-2009 09:18 PM
Framing Documents To Die For NC2X4 Framing 10 02-28-2009 09:45 AM
??? Whats the best way to spread the news about your company? jmgrahamjr Marketing & Sales 21 06-24-2008 03:46 AM
Steel framing prices REDLIUB Framing 5 01-12-2008 10:21 AM
framing a door in a steel stud wall River Rat Dad Framing 5 10-21-2006 06:37 AM
