Steel Framed Wall To Stick Framed Wall
Old 08-31-2008, 05:10 PM   #1
Agolk2's Avatar
Trade: Insurance Restoration and Remodeling Contractor
Hey all,
Anyone got a good idea of a way to go from a steel framed wall to a stick framed wall above it? Studs, 16" O.C.
Project is a hearth and chimney where the framing near the wood stove will need to be non-combustible but then can go to wood higher up the chimney, or do you think we should use steel framing all the way up? I am biased towards wood, so don't mind me .
Thanks
Andrew Golkin
ANG Visuals
www.ANGVisuals.com
(703)898-4430
Agolk2 is offline
Old 09-07-2008, 02:32 PM   #2
Indy Total Construction
indyonline's Avatar
Trade: Contractor
Send a message via Yahoo to indyonline
Re: Steel Framed Wall To Stick Framed Wall
I would say go metal all the way up myself.
indyonline is offline
Old 09-07-2008, 04:50 PM   #3
rustyjames's Avatar
Once you get through the learning curve of using metal, your bias toward wood framing will change.
rustyjames is offline
Retaining Wall Delima - Please help nerd04 Landscaping 5 07-29-2008 10:58 PM
Smooth over painted block wall karma_carpentry Painting & Finish Work 5 05-22-2008 07:58 AM
Anyone have pictures of vaulted ceilings stick framed? TurnkeyConst Framing 28 01-09-2008 09:41 AM
Roof sagging wall pushed out christy Roofing 5 10-14-2006 09:53 PM
How to rock around drain pipe that stick out 1/4in from stud? ruskent Drywall 11 04-27-2006 12:02 AM
