Steel Building/insulation
Old 08-19-2006, 08:13 PM   #21
joasis's Avatar
Re: Steel Building/insulation
I'll second that...welcome Brad...you qualify.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
Old 08-20-2006, 01:30 PM   #22
Bradracer18's Avatar
Trade: Framing
Thanks a lot guys!!!!! I don't post a lot....but do like to learn. I read a lot on here.....I feel information is power. Again, I'm only 21...but I like the construction trade(am going to college to be an engineer though)......it helps me make ends meat while in school, as I'm picky and kinda quick. Anyways, thanks for all of the help guys....I appreciate it, very much so!!!
Thanks again,
Brad
Bradracer18 is offline
Old 08-22-2006, 10:42 AM   #23
Trade: Framing
Hey guys, I've got a few other questions.....just as a matter of opinion(crossing your's with another local guy's). In the 2x6's that run around the building, connecting the poles and allowing the tin to be screwed to.....how many pole barns do you put in each pole?? Next, do you even need to use pole barns all the time, or can a nail gun be used some?? And finally, about the steel.....where the walls come up to the top, and the roof comes down and meets it(or goes over it).....is there flashing or anything you put there?? We don't plan on putting in gutters....so just wondering what keeps the water out. Also, in this area.....about how far do you guys usually let your roof steel overhang(this guy said about 1.5 inches).???
Thanks guys,
Brad
Old 08-22-2006, 06:02 PM   #24
joasis's Avatar
If you want to see how to put up a barn, serch for a post "steel going up" and look at how it should be done.....
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline
Old 08-22-2006, 07:33 PM   #25
unlicensed hack
maj's Avatar
Trade: wood butcher
Thanks guys,
Brad
So you're not going to put the 2x6's in between? You'll have to use 2x nailers on the inside then for the liner steel. So now your walls will be 8 1/2" thick instead of 5 1/2", and you'll use twice as much wood than is needed. But if that's what you want to do.Or aren't you going to insulate and heat it now?
It's called different things..... Eave flashing or gutter apron are two that come to mind. For the junction between wall & roof that is.
1.5 inches is good.
Ya' know Brad, you really just need to get to the lumberyard and pick up a brochure on pole shed construction. Having things illustrated by typing through the internet just ain't gonna cut it!!!
The views expressed in this post are merely opinions of named poster and in no way shall be deemed meaningful by members of the herd. By no means does anything posted by named poster mean a damn thing for anyone else partaking in this thread.
maj is offline
Old 08-22-2006, 10:04 PM   #26
Trade: Framing
Ok, promise I'm done.....I'll get to the lumberyard, tomorrow if I find time.
Not sure what route I want to go with on the nailers yet......we kinda need the extra thickness....to allow for us to set posts outside an existing concrete slab...and still have the inside be over the crete a ways.......we are still insulating too......so I don't know what is the plan quite yet...so many different routes out there!!!
Thanks for everyone's help!!
Brad
glass coated steel haskl33 Excavation & Site Work 3 10-23-2007 11:33 AM
Brick Veneer on steel angle iron sandyman720 Construction 9 07-15-2007 05:20 AM
steel door problem wmerrell Commercial Construction 12 03-24-2007 04:04 PM
Steel K-style gutters?? Jay In Chicago Roofing 7 11-16-2006 07:51 PM
ideas for wood stud wall attachment to steel "I" beam? durham Construction 9 05-10-2006 06:45 PM
