Stained Gutter
Old 12-22-2005, 02:06 PM   #1
locofoco's Avatar
Trade: general remodeling
Question
Stained Gutter
Does anybody know of a product to clean those grey/black streaks off of white aluminum gutter? Powerwashing won't touch it. Tried bleach and all types of soap/hand scrubbing, nothing gets it(all)off. I'm new to power washing- tell me there's an easy solution to this.
Are you guys concerned about using a powerwasher on perforated soffit?
Is it possible to get the inside drywall or insulation wet? Is there a site that gives tips on powerwashing?
Loco
locofoco is offline
Old 12-22-2005, 02:11 PM   #2
Bah Humbug!
Grumpy's Avatar
Re: Stained Gutter
Paint?
Seriously I too haven't found a product to remove those stains either. I fear they are some kind of mildew since they always appear in streaks and usually appear more frequently when gutters have overflow issues.
I wouldn't powerwash soffit, especially if it didn't have a solid wood backing behind it such as newer buildings where there is no wood soffit underheath and if you were to remove the metal you'd have a gaping hole into the attic.
Grumpy is offline
Old 12-22-2005, 05:25 PM   #3
Electrician
erikthered's Avatar
Trade: Electrician
Send a message via AIM to erikthered
Re: Stained Gutter
YA get to your local hardware store and ask for spray 9. it takes the stains right off
erikthered is offline
Old 12-23-2005, 01:11 PM   #4
copusbuilder's Avatar
Trade: Builder/Remodeler- Master Electrician
Re: Stained Gutter
I'll be damned......If you are right then you will make a "spray 9" investor out of me Will have to check that out??
copusbuilder is offline
Old 12-23-2005, 01:31 PM   #5
fez-head's Avatar
Trade: Contractor/ Business Owner/ Entrepreneur
Thumbs up
Re: Stained Gutter
Use a butyl based degreaser like purple power from the autoparts store if your looking for something local or you can also order Gutter Zap on line wich is the best if you have a lot to do.
Sometimes ammonia based cleaner works also. Here is a goldmine of info www.adpub.com/ctimes/links_dat.cfm?section=forum
Good luck,
Jesse
Kirchhoff Handyman Solutions LLC
“Making your Life a Lot Less Complicated’’
www.midmohandyman.com
fez-head is offline
Old 09-13-2010, 01:30 PM   #6
stevenmiles's Avatar
Trade: Construction
Re: Stained Gutter
I used spray 9 it worked great, at first I had my doubts. The results were astonishing!
stevenmiles is offline
Old 09-13-2010, 05:26 PM   #7
BCConstruction's Avatar
Trade: Construction
Re: Stained Gutter
Rv dealers and trailer sellers should stock sprays for this. Over the last 3 years I have tried maybe 6-7 different brands as we also use it on our boat. So far star brite instant streak remover has been the best. Also come's in larger 1 gallon amounts.
http://www.starbrite.com/productdeta...reak%20Remover
Wow this threads 5 years old!
Originally Posted by else bronx View Post
But you cant do Cement work. your a plumber. thats it. by trade. nickels and dimes.
BCConstruction is offline
Old 09-14-2010, 02:20 PM   #8
boman47k's Avatar
Re: Stained Gutter
Loco
If these are the streaks that look to be part of the paint or in the paint with no texture and seemingly protected by a glass coating, spray 9 will get them?
boman47k is offline
Concrete Curb and Gutter Costs stevem Masonry 8 03-20-2007 06:32 PM
gutter coil JT-b72 Windows, Siding and Doors 1 10-03-2006 09:51 AM
Gutter Supplier Gutter22 Roofing 13 08-06-2006 11:08 PM
Shingles hang over gutter robertc65 Roofing 14 07-11-2006 09:58 AM
Hiring Gutter Sub Contractor - Chicago area. Grumpy Help Wanted or Looking For Work 0 04-26-2006 01:49 PM
