Spanning Steel question
hello
We are looking at building a hanging ceiling and not sure of which steel to use.
we are thinking 100mm high, 50mm wide, 6mm thickness L shaped steel and it has to span 4.4m . each span will be holding roughly 40 pieces of 70x35 hardwood.
will the above listed steel span correctly?
also, if this job does prove to difficult and expensive, what other hangin ceiling options are there out there? we are working in a factory space and want to create a hanging/false ceiling to hide the warehouse ceiling.
