Source Of Moisture Damage
Old 09-14-2009, 05:16 PM   #1
72chevy4x4's Avatar
I'm doing some work on a home has a slab crawlspace whcih has a few inches of water in it-it's a bank repo so no electric/pump to get rid of water.
the kitchen floor is a DIY installation-has 1/2" plywood installed over the original vinyl flooring and a failed installation of 12" tile. The tile comes up easily-poor adhesion between plywood/thinset. As I'm tearing into it, by the exterior wall I find previous signs of delamination in the original layer of plywood and the top layer of plywood is moist. failed tile adhesion is obviously b/c of high moisture content in top layer of plywood.
the question is: why is the top layer of plywood wet? afte pulling some of the vinyl sheet flooring back, the subfloor (or luaan) seems to not be wet. no signs of water coming into the room from the exterior wall. could the moisture be coming up through the wet crawlspace, then stopping at the bottom of the 12" tile and soaking the top layer of plywood?
I'm stumped as for a logical conclusion to this.
72chevy4x4 is offline
Old 09-14-2009, 05:32 PM   #2
Its all ball bearings
angus242's Avatar
Trade: Tile
Re: Source Of Moisture Damage
What it sounds like to me is the water source is above the floor. It's wetting the top layer of ply and then finding its way into the basement through, perhaps a passage to the basement like a frig water line or electrical/plumbing. Vinyl is keeping everything else under it dry.
As for the failed tile, it's from the crappy DIY installation. Tile over vinyl is not the way to do it. The original vinyl should have been removed. There should have been either a membrane or CBU used directly under the tile. I doubt it was even EGP to begin with. Probably used mastic to adhere too. Sounds like the tile was doomed even before the water
Angus
L+M+O+P=Chttp://www.millan.net/minimations/smileys/einstein3.gif
"Promise only what you can deliver. Then deliver more than you promise"
angus242 is online now
Old 09-14-2009, 05:49 PM   #3
72chevy4x4's Avatar
for clarification, it was original subfloor, sheet vinyl, 1/2" plywood then tile. good call on mastic-there were some areas where it was used :-(
no utilities in the house. water is from lots of rain last week.
Old 09-14-2009, 11:35 PM   #4
angus242's Avatar
Trade: Tile
I still think the source is above the floor. If it were wicking up from below the vinyl would block a lot of it so the ply wouldn't be as wet as it is.
Regardless, tile job was hacked!
Angus
water damage and condensation bigblue General Discussion 2 01-10-2009 01:11 PM
Moisture Moisture Moisture... fixitpete Flooring 22 12-30-2008 04:13 AM
Crawl Space Ventilation Ed the Roofer Roofing 2 11-27-2008 11:15 AM
Tenwolde's 5 Myths Of Moisture Ed the Roofer Roofing 3 02-10-2008 03:37 PM
