Trade: remodeler
Soundproofing A Room. Experience With Materials?
Hi all,
I have three sound rooms to quote on. Two theaters and 1 master bedroom. Two customers total. On other forums dedicated to recording studios and home theaters, you see a lot of exotic materials used. I was wondering how many of them you guys have seen: Quiet Rock Supress (drywall) Green Glue Various resilient clips and hat track I figure if these items work, others would be using them. Guys I know use extra drywall or soundboard, maybe fiberglass. Thanks! James |
Construction Estimator
Trade: Estimator
Re: Soundproofing A Room. Experience With Materials?
Quiet rock..... waste of money $70-$80 per sheet no way! You want to kill the sound in a couple ways. Use thick batt insulation R-19 or greater in the wall cavity. Then use RC1 channels (kinda like hat channel but with only 1 leg) They have cut outs along the length of them to stop sound vibration from traveling thru walls. You can add a layer of sound board (homosote panels in some areas) Over them for added security from sound/vibrations. This takes care of the sound traveling thru walls. Now to keep it from echoing around the room. there are many comercial sound panels available. All work very well. Almost all are very expensive. It is up to the owners what type of finish look they want. I have built sound panels before for a very low cost. You construct a box frame and fill it with batt insulation to the dimensions you want. then simply wrap the panels in a decorator fabric pulled tight and stapled to the back. Have you ever been in an attic and noticed the sound reduction you get from the exposed insulation? Same principle. You might want to use a more porous fabric so sound will penitrate and not bounce off.
A buck a foot is not an estimate! It's a crap shoot! |
Here - Quite rock is $130.00 per sheet....2nd that point = waste of Money.
As DaveH said...= use insulation, actually use ACOUSTIC insulation, it's less expensive (without vapor barrier). Installing some in a ceiling tomorrow. You can also use 'sound board' if you want to get out cheap. If you want to do it right, it's just as DaveH wrote. The key is to construct 'chambers' in the wall to absorb the sound. That is the basis behind the RC1 channel Dave described. Actually, we have another job like this scheduled for next month in an apartment complex connected to the 'swimming pool pump room'. We will be using a new product made from rubber attached onto the walls - and the channel on the installation. Don't ask me what the product is, I am not directly handling this account. My biz. partner is, he doesn't care about the technicalities (sp.)....
- Build Well - |
Trade: remodeler
So when you say "chambers", you're meaning what, like independent air cavities?
Thanks a lot for the responses, by the way. I appreciate the insights. |
#5 | |
...jammin
Trade: Rock Disciple
There's sound proofing and sound absorbing
For sound proofing, a layer of this stuff under the Sheetrock works well ![]() Vinyl Sound Barrier is used to block unwanted noise. Increases Wall Mass without increasing its Depth -- only 1/8" thick Prevents unwanted sound transmission through walls, ceilings, and floors. STC=27 54 inches wide. Available in full rolls 20', 30', 60' ... or by the linear foot. Weight: 1 lb. per sq. ft. Thickness: 1/8” ![]() A wall of homosote under the Sheetrock works well also Firring strips and a pocket of air between can help with that The acoustic panels are a different animal They are used to absorb sound, not block it They are great for echoes and unwanted frequencies They can also help with the sound proofing if those are the frequencies that are bleeding out ![]() An example combo of wall and suspended wall and ceiling panels: ![]() That's pretty fancy If it's the bass bleeding over there are special bass eaters in box, panel, and even drop ceiling panel form There's a lot involved Most of which is specific to the project Construction materials and room shapes etc... It wouldn't be a bad idea to talk to an acoustician They can usually tell from specs and pics what's going on and have some specific suggestions
Signature Quote Quote:
Trade: remodeler
Slickshift,
Thanks for the info! I've looked at vinyl sound barrier materials before. It seems so logical to put a big, heavy rubber-like thing in your wall. Actually I've read data and articles, and never even seen a piece. What I've read, however, is that it's a source of mass, but the fact that it's limp doesn't actually translate into a benefit. The STC 27 that's referenced won't add 27 STC points to a structure, and maybe adds a few points only. Again, I haven't used it but there's a couple of websites where that product is pretty directly compared to just another sheet of drywall. Now those acoustic panels are slick. So those would be sound absorbing you mentioned? Like used after the soundproofing job is done? I'm not involved in that part, actually. There is a gearhead hooking up speakers, and I imagine he'll handle the room stuff. Thanks for taking the time to post all of that. Do you sell these items? |
#7 | |||||
...jammin
Re: Soundproofing A Room. Experience With Materials?Quote:
The idea behind it is to put the mass of a thick piece of something into a thin sheet It's extremely effective I've never heard the fact that it's limp has any effect on it It's not meant to be a structure or part of a structure About the STC points, I'm not a numbers guy, I let Nick the acoustician rattle off those things (...till my eyes glaze over lol) From an actual seat of the pants feel I'd say it adds a lot more It's impressive Quote:
But I can tell you: Another sheet of drywall is pretty effective Two sheets of different types of drywall are more effective than two of the same types The type of mass of the VSB is really different than drywall, or homosote Just looking at the final numbers or ratings does not tell the whole story with acoustics, there's other factors such as frequencies and resonance involved A homosote/VSB/drywall sandwich is way more effective than drywall/drywall/drywall Quote:
They can be used after the sound proofing is done, but are also used in conjunction with sound proofing They can help eliminate bleed through in general or in certain frequencies Most often they are used not for sound-proofing per say, but ridding a room/space of echoes and unwanted resonances Depending upon what the customer's wants/needs are, it's best to build the room properly, and with acoustics in mind It's much harder to "go back" and install sound blockers after the room is built (if the customer says too much sound is bleeding through), then try and play catch-up with absorbers They can only help so much Quote:
Yes, I'm a dealer/installer
Trade: remodeler
Hi Slickshift,
Thanks again for the replies. Is this vinyl hard to install?? I mean a sheet of drywall's pretty easy. Heavy vinyl seems like it might eat up labor $$. You've got some great info here. I'm going to point the equipment guy in your direction to look at those panels. James |
#9 | |
...jammin
I never though of it as hard to install
It's not my primary though Most of my projects with it have been relatively small and pretty specific (My experience has been more retro-fitting or part of a remodel, and commercial "one-wall" deals like a gym with disco music next to a relaxation spa in a commercial building) It is a bit heavy and floppy I'd say it's not really a one-man job, though I've done smaller work with it by myself, you really need a helper I'll gladly try and help you or your guy on the panels I'd suggest dealing directly with the supplier, they are very nice to do business with, and they have acousticians on staff that can give you the engineering low-down, and great job specific suggestions Let me know if you'd like the contact info
Back from the dead...
Trade: Paperhanger/Painter
Word of the day = acousticians
Use it three times today in seperate conversations, and I'll hang the vinyl sound barrier for free. ![]() You will also buy me a prime rib dinner (Captain's cut), several cases of beer, and loan me your daughter for one night, no questions asked. Last edited by ProWallGuy; 06-14-2006 at 05:46 PM. |
#11 | ||
...jammin
I've been every one of them at one time or another.
Been more than one at the same time too. On the same note, my wife belongs to the Lee family. Her sisters are Beast, Home, and Ug. |
#13 | |
...jammin
Lol
Then she's adopted...I've seen pics ProWallWife = Hottie hey look new smilies
#14 | |
#15 | |
...jammin
Re: Soundproofing A Room. Experience With Materials? Another informative thread ruined by our juvenile banter
Trade: remodeler
That's just hysterical!
I'd love a dealer name, if that's OK. Thanks! |
James, sorry we took your thread a wee bit off-track. If you opt for an acoustical wallcovering, and need a qualified installer, let me know. I got paperhanger connections all over the US thanks to the NGPP.
#18 | |
...jammin
And I'm sure it's OK to post this here
I can recommend them: Acoustics First 888-765-2900 227 Tomlyn Street Richmond, VA 23230-3334 http://www.acousticsfirst.com/ The info package you'd get in the mail is much more complete than the website If you or your guy wants to set up as a dealer/installer, you (should) get a discount (I assume they still do that) If Nick the acoustician is still there, you can send him specs and/or pictures His son works there too, but I'm not sure if he's an acoustician or a tech or what If Nick's not there, I'm sure they'll have another acoustician on hand ha ha PWG, you have to hang some VSB in my garage now It's going to be the new rehearsal studio for the band
#19 | |
#20 | ||
...jammin
| Advice with room addition and blueprints | A.W.Davis | Remodeling | 35 | 03-28-2007 07:32 PM |
| Florida Licensing Service and Experience Requirements | DoubleJ | Contractor Licensing | 0 | 03-21-2007 02:47 PM |
| Room to room fan | dkillianjr | Electrical | 12 | 12-14-2006 01:08 AM |
| Room to room fan | Larry007 | HVAC | 5 | 11-24-2006 01:07 PM |
| Experience | denick | General Discussion | 17 | 08-11-2006 11:10 AM |
