Sound Proofing
Old 12-20-2006, 02:05 PM   #1
JamesNLA's Avatar
Trade: Plumbing & Electrical
Sound Proofing
Hi all,
Gotta project I am starting soon. The addition is in a factory. It's a very noisy factory, and the room we are building is an office/meeting room. Noise is an issue, aside from insulation, what else is there that works very well. My customer made a clear point to mention this to us at least a few times. Nothing has been built as of yet. Room is 15 X 23.
Were rocking the inside, and 3/4 ply on the outside of the addition. It will be 4 new walls with a small hallway to existing.
Thanks
JamesNLA is offline
Old 12-20-2006, 02:18 PM   #2
Partner/Carpenter
genbuilers's Avatar
Trade: Carpentry Sub-Contractor
Re: Sound Proofing
What has worked for me in the past is this. Build a wall with 2x6 plates (top and bottom) and 2x4 studs. You will have to buy twice as many studs. Off set them from one side of the room to the other. Basically hold 2x4 flush on oneside 16 on center and on the other side of wall hold flush but nail them in the center of the other side. Then wieave insulation in between the studs. Double sheetrock, overlapping seams. Do not forget to seal the bottom plate to floor with good quality sealent. And I would get a good door (not a hollow door) Has anyone else done it this way?
genbuilers is offline
Old 12-20-2006, 05:17 PM   #3
...jammin
slickshift's Avatar
Trade: Rock Disciple
Re: Sound Proofing
For some info, see the threads:
http://www.contractortalk.com/showth...fing+absorbing
and
Signature Quote
slickshift is offline
Sound Proofing a Bathroom RussellF Remodeling 19 11-22-2011 11:23 PM
Inexpensive sound proofing methods Humble Abode Construction 30 10-27-2006 07:18 AM
Damp proofing / water proofing denick Excavation & Site Work 5 04-21-2006 05:21 PM
sound proofing izote61 Construction 6 12-09-2005 09:16 AM
Sound Proofing HVAC Equipment hoek HVAC 1 10-05-2005 10:42 AM
