Trade: design engineer
Slot Drains
i'm interested in using a slot channel, not sure on the look but coud be OK. It is called Duraslot. Does anyone have any experience using it? i'm concerned the slot might be a bit under engineered and may not last long?
Trade: plumbing and heating
Re: Slot Drains
I've never seen them public or private. But, I think you should contact them with your'e engineering concerns.
Superintendent
Trade: Concrete Foundations and Flatwork
Re: Slot Drains
Looks like a good product, but like all of them, proper installation is what matters. I've seen a similar product using a galvanized steel slot welded to corregated metal pipe storm drain.
There are numerous forms of trench drains, all achieving the same result.
______________________________________________ A reasonable expectation becomes an assumption when it goes wrong. |
#4 | |
Trade: underground
Re: Slot DrainsQuote:
If your application is light duty, there are better products. |
Superintendent
Re: Slot Drains
Yep, if it is residential drainage in front of a garage, you may have more economical options. Just keep in mind access to maintaining the drain. The owner may need to remove the drain cover to clean the trench, be it a pre-fabbed system or a slot to drain pipe. BTW, if you choose a slot to drain pipe, ensure that you have a poured invert in the pipe which lessens maintainence.
| curtain drains | maintenance man | Excavation & Site Work | 7 | 06-13-2007 09:06 PM |
| A B C slot cutting for recompaction. | MC Excavating | Excavation & Site Work | 17 | 03-13-2007 07:04 AM |
| Strange and bad English translation | CE1 | Off Topic (Non Trade) | 4 | 09-01-2006 09:33 PM |
| Footing Drains | jjtt | Excavation & Site Work | 27 | 07-17-2006 10:28 PM |
| The little slot | Gordo | General Discussion | 19 | 05-01-2006 08:30 PM |
