Slab On Grade
Old 02-15-2009, 01:26 PM   #1
civil engineer
mjaafreh2008's Avatar
Trade: building
Slab On Grade
hi evry one , i was wondering what is the need of the base course layer which need to be excuted under the slab on grade , and if i used a single size crushed stone instead of nutural filling material , is it right to use base course on top of it ,,,?
mjaafreh2008 is offline
Old 02-15-2009, 01:40 PM   #2
Re: Slab On Grade
Around here pea gravel would be
the most common fill under a
residential slab.
Don' know what is available,
where ever you are.
neolitic is offline
Old 02-16-2009, 12:13 AM   #3
Pro Deck Builder
AutumnWood Inc.'s Avatar
Trade: Deck Builder
Re: Slab On Grade
A Civil engineer needs to know what to use for a base material/slab....
and there trade is building....
AutumnWood Inc. is online now
Old 02-16-2009, 12:41 AM   #4
Super B
skyhook's Avatar
Re: Slab On Grade
Pea gravel or aggregate would give the slab a cushion to move on in the event of an earthquake and also give the concrete a more uniform substrate to make it stronger. Separating the slab from highly expansive soil such as clay.
skyhook is offline
The Following User Says Thank You to skyhook For This Useful Post:
SWAY79 (02-16-2009)
Old 02-16-2009, 01:15 PM   #5
strightclaw's Avatar
Trade: Gereral Contractor
Re: Slab On Grade
Generally speaking anything from Sand to # 57 stone is used under the Slab as a Vapor Barrier this is almost always covered with plastic something like 4mill ploy.If your outside such as a sidewalk or driveway no need for this just set the grade an go to it.
strightclaw is offline
Old 02-16-2009, 01:23 PM   #6
Ant D.
D.A.S.Anthony's Avatar
Trade: Construction Management, General Contractor
Re: Slab On Grade
If you truly are in the middle east I haen't a clue what to use. I can't even begin to imagine the unsetttling sand or earth that you are trying to build on over there.
Anthony
_____________________________
www.dasassociates.com Building from Greenwich to Fairfield and Westchester Counties.
D.A.S.Anthony is offline
Old 02-16-2009, 01:34 PM   #7
Thom
thom's Avatar
Re: Slab On Grade
Here in Albuquerque almost all homes are slab-on-grade.
We are in a desert, there is little organic matter in the soil, and things are very dry.
We grade, tamp, and pour. Generally, if fill is needed, local fill is just fine. We don't install vapor barriers.
thom is offline
Old 02-16-2009, 01:45 PM   #8
Super B
skyhook's Avatar
Re: Slab On Grade
Minimum vapor barrier in SoCal is 6 mil.
skyhook is offline
Old 02-16-2009, 07:12 PM   #9
72chevy4x4's Avatar
Re: Slab On Grade
question about vapor barrier in basement pours, what's the likelyhood the plastic will get torn during the pour-either with tools, rebar or by puncturing it on the stone (probably not if you're using pea gravel)?
Has anyone ever tamped the gravel then laid foam board down, then poured concrete for a basement floor? It would make a thermal barrier, but not sure about the gravel to foam board being a good surface to pour upon.
72chevy4x4 is offline
Old 02-16-2009, 07:38 PM   #10
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Re: Slab On Grade
We just did one and engineer spec'd Stego-Wrap 15 mil.
Chris
Chris Johnson is offline
Old 02-16-2009, 08:35 PM   #11
Sean
SLSTech's Avatar
Re: Slab On Grade
About a 100% - go vapor barrier / plastic, taped, then foam board
SLSTech is offline
Another wood subfloor over concrete slab GreenBuilder Carpentry 3 05-08-2008 01:20 PM
Demo a foundation under a radiant heat slab without disturbing the slab...? wackman Remodeling 18 04-02-2007 12:38 AM
Slab on grade house. ICF? ARCS Construction 3 12-21-2006 04:00 PM
Slab on Grade fill options? James Ellis Construction 10 10-24-2006 01:55 AM
5" pored concrete slab on grade? Nac Masonry 1 04-25-2006 07:53 PM
