Trade: inside journeyman wireman
Sistering A Truss Joist
I'm new to the forum and could use some structural advice. I'm moving into a new construction home in West Palm, Fl; and will install a laddered attic-access door from a scuttle hole that's too small for my needs. Attic access is in the garage, and will be not be insulated to R30, as wil be the air conditioned ceiling elsewhere in the home.
Currently the joists (truss joists) are 24" OC and I'm considering installing the door in such a way to require removing approximately 5' of a joist to gain wider access. I realize that truss joists which support the roof's weight are not to be compromised as can regular ceiling joists. From what I've been able to gather, sistering the joist I'm to cut through is the way to do it. I'm unfamiliar with exactly how this is done. I'm thinking that after cutting away the section of the joist I need removed; I only need to frame in the new rectangular opening in such a way as to ensure the compromised joist can move neither outwards or inwards. I'd accomplish this by doubling-up on 2x8's and framing in a box to accomodate the new door. I'd glue and screw and use joist hanger brackets; most likely. I'm an electrician and have fair knowledge of stucture, but am not a structural engineer. I'd like to know if I have the concept right, and if my proposed step sounds safe. Thanks to all. Larry. |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
Geometrist
![]() ![]() Trade: framing/remodeling
Rewards Points: 6,411
Re: Sistering A Truss Joist
Incorrect and unsafe. If the house is in fact new, contact the truss manufacturer and ask for an engineered change. Anything else is a crapshoot even for a seasoned pro.
Advertisement |
The Following User Says Thank You to Warren For This Useful Post: |
CanningCustom (10-07-2011)
Rewards Points: 2,040
A trussed joist you don't want to mess with without engineering right from the truss manufacturer. Probably not a huge deal, not like the place is going to fall down or anything, but more than likely the truss designer will tell you what you need to do without charge. Could you possibly move the one truss over?
If you correct your mind, the rest of your life will fall into place ~Lao Tzu SalmonFallsCabinetry.com Salmon Falls Cabinetry on Facebook |
Thank you both. I've read more than once in my searches to contact the manufacturer or hire a structural engineer for assistance. I suppose I had a pipe dream that someone would say something like, "oh, that's fairly straightforward, just. . .. (do this), but as I suspected, my original searches yielded rational information. I'll take my own advice--that I give to apprentices and, "do it right." Three words that so many can't fathom. It's just not as cut and dry as I suspected it might have been. I can accept defeat.
![]() Thanks again, all. |
Geometrist
The problem with messing with trusses, is that every web does so many different things. Thats why you see 40' long trusses made from just 2x4's. Working together the way they were designed, the webs make the whole truss work. Any modification moves stress points to spots they were not intended. I have seen some truss modifications that seemed really minor that were actually quite involved.
#6 | |
Trade: Design/Build Remodeler
Rewards Points: 670
Re: Sistering A Truss JoistQuote:
I love what I do and I'm very good at it! Da Vinci on the web or Da Vinci On Facebook |
Ex Nail Pounder
Trade: General Contracting
Rewards Points: 150
Is it really a truss joist or is it a TJI?
#8 | ||
![]() Quote:
It appears to be a bare-bones truss joist system. I see no provisions for an engineered floor in the attic. The attic "floor" would simply be the lowermost, horizontal section of roof truss, comprised by the 2x6 that spans the home, and nothing more. Last edited by sparkyjw; 10-06-2011 at 06:23 PM. |
After reading Rusty's response, I waited to hear from you as to what you had, since he did point out that there may be some confusion, and I still think that there is a little.
Just an FYI for future reference: These are I-Joists. Many will call them TJI's, which is a company called TrusJoist International and will just get shortened to Trus Joist. Most will understand what you mean when the material is right in front of you, but talking about it on a forum can create a little confusion. ![]() These are trussed joists, or open webbed floor trusses. This is what I felt that you were talking about. After reading your last post, I think you may be talking about either plain ol' trusses (though I have not seen 2x6 bottom chords) or you are referring to attic trusses ![]()
Thanks for the replies, all. Perhaps some pictures will help. These are pics of the place during construction. The shots taken from the ground are a bit confusing due to plane of reference.
I recall looking at the prints and seeing the term "truss joists." I saw my trusses staged on the ground before they were mounted above the block walls of the house. I noticed that the joists to which the drywall ceiling would be mounted were the truss bottoms I saw on the ground. Hopefully I'm not creating confusion by using incorrect terms. Hope the pics help. ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Geometrist
No "H" clips on plywood in Florida? Is there a ridge vent? I know this has nothing to do with your question, I was just curious.
Re: Sistering A Truss Joist |
#13 | |
Those are regular trusses sparky. No attic trusses. You are going to need to call your truss manufacturer to see even if there is even the slightest possibility that they have any options for you. But no, do not cut any part of the truss. About all you can do would be to move it over, but then you'd need to head it off, which usually requires a girder truss. And being in Florida....you may be out of luck. I don't think I've ever seen a cinder block home before. Garages, sure....but not homes. I can understand the reasoning with the hurricanes you guys have.
The Following User Says Thank You to Kent Whitten For This Useful Post: |
sparkyjw (10-07-2011)
Rewards Points: 430
Looks to me like you're stuck with a maximum 22-1/2" wide attic stairs.
The Following User Says Thank You to txgencon For This Useful Post: |
#15 | |
![]() It's becoming more common to see homes entirely built with CBC in Florida, and yes, hurricanes are the reason. I suppose I can live with that, txgencon. As I stated above, if it was a no brainer scenario, I'd cut away; but that's not going to be the case, it seems. I'm not looking to change things if I run the risk of compromising the structural integrity of the house. |
Re: Sistering A Truss Joist![]() |
General Contractor
Rewards Points: 7,238
I wouldn't mess with the trusses unless you talk to an architect or engineer. Each truss is designed support the span and the load they will carry. Right now you have a small access opening in the garage which is used for minimal storage or it could be a fire access depending on the local code... installing pull down stair will mean that you plan to create a larger storage space then it was designed to be, which means you will add plywood, you will be walking up there and who knows how much stuff you plan to put up there... therefor you will exceed the DL and LL on that trusses they meant to support and chances are the system will fail or ceiling will sag or collapse.
The Following User Says Thank You to greg24k For This Useful Post: |
#18 |
Trade: Interior Remodeling Specialists
Who stood up those rafters and layed them out
![]() ![]() 10th post- 4th picture- 2nd 3rd and 4th rafters to the right of roof centerline., WTF! Looks like an electrician framed that area ![]() ![]() Last edited by SSC; 10-07-2011 at 08:14 AM. |
The Following 2 Users Say Thank You to SSC For This Useful Post: |
CanningCustom (10-07-2011),
Splinter hands (10-08-2011)
#19 |
Trade: Exterior Remodeling
Rewards Points: 756
Personally I don't like 1/2 sheeting on a roof, around here no one even uses H clips, why I don't know. Used 3/4 T&G when I did my own house.
#20 | |
BTW, did you mean to say Stevie Wonder framed that area? ![]() AdvertisementLast edited by sparkyjw; 10-07-2011 at 09:55 AM. |
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
Replacing rotted rim joist entry door...first timer! | r1dannyzx | Carpentry | 22 | 04-20-2011 04:06 PM |
Time diff to stick roof versus truss | UpNorth | Framing | 51 | 09-27-2010 04:21 PM |
Deck Screws vs Joist Nails | subybohn | Decks & Fencing | 100 | 11-25-2009 02:52 PM |
Cut a truss? Never. Almost | Tim Garrison PE | Carpentry | 23 | 11-01-2009 11:53 AM |
??? Whats the best way to spread the news about your company? | jmgrahamjr | Marketing & Sales | 21 | 06-24-2008 03:46 AM |
Go to Page... |
