Single Laser Level That Can Do These Tasks..
Old 12-01-2017, 07:19 PM   #1
quantumflux's Avatar
Trade: General
Rewards Points: 162
Does anyone know of a single good level that can:
Interior applications:
* 5 point alignment for squaring, plumbing and leveling, such as:
https://www.boschtools.com/us/en/bos...l-25-123123-p/
Exterior applications:
* Can have a receiver mounted to a excavator to dig to a certain depth
* Can used a hand held receiver to check for proper depth of trench
* Can do a slope
Like the topcon laser/receivers...
However, I don't want to buy multiple levels, are there any that can do "all of the above" that anyone is aware of?
Thanks!
quantumflux is offline
Old 12-01-2017, 09:54 PM   #2
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 1,916
Re: Single Laser Level That Can Do These Tasks..
As far as I know, no.
Lasers for interior work have a very bright line, but by the nature of the thing, it is less accurate. The line is quite thick.
Exterior lasers, on the other hand, are difficult to see inside, and downright impossible to see out of doors. They pretty much require a detector. But they also have a range of 500-1,000 or more feet. And accuracy can be around 1/16" at 100'.
As far as shooting slope, the only one's I know of are pretty pricey, like 1,500 dollar range. David White and CST/Berger are good brands. These are only exterior, and require a detector. The one on my wishlist has a 2,000' range.
Delta
I have an Edifice Complex.
quantumflux (12-03-2017)
Old 12-02-2017, 12:03 AM   #3
jhark123's Avatar
Trade: Pro Cat Herder
Rewards Points: 1,622
nope, you'll need two
jhark123 is offline
Old 12-02-2017, 03:57 AM   #4
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 2,472
https://www.tigersupplies.com/Produc...PLS60574-.aspx
Big Johnson is offline
Old 12-19-2017, 10:05 AM   #5
Unger.const's Avatar
Rewards Points: 2,610
I think your asking how to buy a prius that can haul like a one ton truck.
I really like my dewalt green 3 line. It gives three 360 degree lines. So if all 3 lines are on it will cross 6 times like a 6 point for laser. Shows very bright in a bright room. Exterior is tough during daylight. The little reflective plate it comes with helps.
Exterior wise I break out the Bosch rotary laser.
Unger.const is online now
12" Tile on uneven & un- level sub floor... DGEC Tiling 33 10-09-2017 01:53 PM
Rotary Laser Level mstrat Tools & Equipment 14 03-08-2017 09:18 AM
Bosch GRL250HV Laser Level ROVACON Tools & Equipment 2 10-29-2011 03:03 PM
Laser level for top plates on partition walls? personalt Framing 3 11-12-2006 08:58 AM
