Trade: LANDSCAPER
Sidewalk Pour
I'm pouring about 1/2 yards of concrete replacing a sidewalk piece. Do I have to put some material between the new concrete and the old concrete sidewalk so the stuff affixes to the old properly or just pour the concrete in?
solar guy
Trade: solar contracting
Re: Sidewalk Pour
you could drill into the edges of the old walk and grout in some rebar or you could just pour in the new
Trailer park boy
Re: Sidewalk Pour
Like nap said, I would pin them.
"Industry without art is brutality"
Re: Sidewalk Pour
If you decide not to pin it, which would be best, At least make sure to paint the existing edge with a good wet slurry mix just prior to the pour. , you could also get in tight with a grinder and rough up the existing edge. G
Professional Instigator
Re: Sidewalk Pour
Install rebar like stated and a paint a bonding agent on the old concrete
Thom
Re: Sidewalk Pour
You guys do it different. We don't put steel in our sidewalks unless they cross a drivepad. Here we would just finish a control joint at each end or put an expansion at one end and a control joint at the other end.
| The Following 2 Users Say Thank You to thom For This Useful Post: | greg24k (05-21-2009), JustaFramer (05-21-2009) |
Trade: carpenter
Re: Sidewalk Pour
I have never doweled sidewalk... expansion joint is all you need.. for four foot walk i cut control joints every 4 feet. dowels are mainly for transferring a load from one slab to another.. sidewalk dont carry this kind of load.
| The Following 2 Users Say Thank You to master of none For This Useful Post: | greg24k (05-21-2009), JustaFramer (05-21-2009) |
Trade: Residental/Light Commercial Contractor
Re: Sidewalk Pour
if your not tying into an existing sidewalk, no need to dowel just pour it solid. saw-cut your joints 1/4th the thickness of your slab within 4 to 12 hours of your pour. every 4' to 6' will control cracking. Be sure to edge the slab & use a broom finish.
Trade: carpenter
Re: Sidewalk Pour
I think you saw cut control joints. expansion is not controlled by saw cuts. if your pouring between two pieces of concrete you need to put expansion joints in... around here you need them every thirty feet
Priced In
Trade: Exiled For Life
Re: Sidewalk Pour
Thom and master of none are correct. expasion joint is all that is needed. if you don't want to look of EJ then use a cap on the EJ. Tear the cap off and use caulk. Not painters caulk either.
#11 | |
Trailer park boy
Re: Sidewalk PourQuote:
There is a very good chance that a slab like that without being pinned would be heaved after one winter and then the joints are tripping hazards.
Re: Sidewalk Pour
If its not pinned and tied together with rebar in DC they would steal the sidewalk
solar guy
Re: Sidewalk Pour |
| I need a to pour 1/4 yard of black concrete... | ruskent | Masonry | 9 | 05-25-2009 12:50 PM |
| To what Level pour slab? See Picture | sethNaga | Construction | 4 | 04-26-2009 09:27 PM |
| concrete pour on top of brick stoop | 72chevy4x4 | Masonry | 0 | 09-11-2008 10:09 PM |
| Too cold to pour concrete sidewalk? | haskl33 | Masonry | 8 | 12-04-2006 07:00 AM |
| How would you pour a Sidewalk | cbelawn | Masonry | 11 | 11-23-2006 07:13 PM |
