unlicensed hack
Trade: wood butcher
Shed Roof Ventilation
This has probably been discussed somewhere here, but could'nt find anything in threads. I'm done framing a 2 story addition with 1 story shed roofs on both ends. My concern is how to ventilate the shed roofs, since they die into the 2 story wall. Pitch is 5 in 12. It is all felted & D-edged, so shingling will be happening soon.
I have some ideas, but thought I would toss it out there for suggestions. I'm a little concerned with wind blown snow getting in at the top if I vent it with a continuous vent. |
Trade: Remodeling contractor
Re: Shed Roof Ventilation
Coravent is made so you can remove half of one side so you put the courogaded area on the roof & the "stripped" portion up the sidewall. Cut a 3" strip off the roof sheathing and you have your air flow.
Trade: Builder/remodler
Ridge master is also another product that you can use and it is realy easy
Trade: Residential custom home builder
There's no reason you can't use regular roof vents. Just keep them far enough below the wall that they don't get drifted over easily. I install them after shingles, BTW. Cut a 9x12 hole, pull the nails at the sides, slide the vent in under all but the bottom row of shingles, renail. Much faster than fitting shingles to it.
Clint - carpenter, coordinator, webmaster |
#5 | |
unlicensed hack
Trade: wood butcher
Re: Shed Roof VentilationQuote:
The vents are in and roof shingled. I used the Coravent with one side cut off and turned up the wall. Then I bent some coilstock to match color of siding to cover it with. Sorry I didn't post back, but I found exactly what I needed on the Coravent web site, then ordered some through lumberyard. Seems like it is the perfect solution. Thanks anyways.
Bah Humbug!
Mushroom vents or a roof to wall vent. I've never actually installed a roof to wall vent though I have seen it on a few architect's specs before.
So where is the air path in that solution?
unlicensed hack
Trade: wood butcher
Same as any other vented roof, through the vented soffit and out the ridge vent(except this is actually half of a ridge vent).
I'm not quite sure why you ask this Red, am I missing something or is there a better solution? I'm always up for better solutions |
Maybe I'm misunderstanding what Coravent is. Never mind.
| Venting of Cathedral Ceiling on Shed type roof | sandyman720 | Roofing | 4 | 07-30-2007 08:14 AM |
| Low Pitch Roof solutions | Fixer | Roofing | 4 | 02-18-2007 11:09 AM |
| Ideas for venting a shed roof.... | kermmonk | Roofing | 5 | 08-16-2006 09:40 PM |
| Torch down(flat roof) leaks BAD...can you give advice ASAP? | Detail Guy | Roofing | 21 | 01-16-2006 02:36 PM |
| Do You Need A New Roof ??? | Perfect Roofing | Roofing | 0 | 02-10-2005 02:46 AM |
