Sheathing
Old 11-14-2005, 09:43 AM   #1
Speck's Avatar
Sheathing
What is the difference between gypsum sheathing and OSB 7/16 sheathing? Can I use OSB under stucco?
Speck is offline
Old 11-14-2005, 04:22 PM   #2
ELM's Avatar
Re: Sheathing
And you guys were pick'in on my thread.
ELM is offline
Old 11-14-2005, 09:05 PM   #3
Speck's Avatar
Re: Sheathing
I guess I should have said it differently. I KNOW what gypsum and OSB are.
The gist of my question is, I know you use gypsum on your walls and OSB on the outside corner for support on stucco walls, but can you use OSB on all outside walls deleting the need for gypsum? ( I guess every board has it's )
Speck is offline
Old 11-14-2005, 09:28 PM   #4
Priced In
JustaFramer's Avatar
Trade: Exiled For Life
Re: Sheathing
We use OSB or Plywood on stucco applications here. The only time gyp is used is when a type x fire rating is needed even then that is in combination with ply or osb.
JustaFramer is offline
Old 11-15-2005, 07:42 AM   #5
Custom Builder
Glasshousebltr's Avatar
Re: Sheathing
Weatherall in Sanders Indiana makes a direct applied stucco that with the proper preb works really well over OSB. In fact, if I remember correctly it's the recommended sub strat.
Bob
Bob
Glasshousebltr is offline
Old 11-15-2005, 09:15 AM   #6
RobertCDF's Avatar
Trade: Custom deck builder
Re: Sheathing
around here every one uses OSB for everything, walls and roofs (except the cheap builders who still mix celotex in wherever they can. They paper it and chicken wire then stucco seems to work fine but you should gap each seam AT LEAST an 8 penny nail 16 penny is the best though.
RobertCDF is online now
Old 12-30-2005, 04:07 PM   #7
mightpeak's Avatar
Trade: EIFS- Stucco - Hardboard (RhineRock) Exterior
Re: Sheathing
I have found an amazing new fiber reinforced cement board that could replace most sheating, stucco issues. This stuff comes in 1/8" and 1/4" thickness and is cost effective. You can direct apply stucco finish and have the same effect as 1/4" plaster. It's called RhinRok. Cool inovative stuff.
Gregory Musewski
MMI
Ph. # 907.644.2313
Fax # 907.644.2332
customerservice@mkote.com
www.mkote.com
mightpeak is offline
Exterior Wall Sheathing in B.C., Canada? wallmaxx Framing 9 01-21-2008 01:10 AM
Non wooden exterior sheathing myshtern Framing 2 06-30-2007 05:31 PM
What do you shoot your sheathing with? Webs Framing 16 03-19-2007 03:33 PM
sheathing opinion jiman3 Windows, Siding and Doors 6 08-16-2006 09:42 PM
MDO as both siding & sheathing karma_carpentry Carpentry 8 07-30-2006 09:35 PM
