Self-Adhered Water Resistive Air Barrier Membrane, (house Wrap.)
Old 10-08-2017, 01:34 PM   #41
Tom Struble's Avatar
Trade: siding
Rewards Points: 4
Re: Self-Adhered Water Resistive Air Barrier Membrane, (house Wrap.)
Originally Posted by Dirtywhiteboy View Post
You laugh at of what you don't know. The old Japanese carpenter that built this island really knew what they were doing!! The siding on the home I live in is the siding on the outside and the interior wall on inside. The wall is " thick. No water comes through the wall!!!!!
We don't use the thin plastic garbage that blows down the road when a storm hits.
Here's a nice read..
Single Wall Construction
Many of the older homes in Hawaii were constructed with only a single exterior wall, which is often referred to as single wall construction. The original purpose of single wall construction was to save on costs because most building material has to be shipped in from the mainland. Single wall construction is possible in Hawaii primarily because there is no need to insulate against the cold. Many of these single wall homes have louvered windows to throttle the cooling effect of the trade winds. Since the wood used in single wall construction is exposed to the elements, redwood or cedar are preferred for their termite and dryrot resistance. In the 1980's, the price of redwood and cedar increased, offsetting the cost advantages single wall construction once held. Since double wall construction requires slightly less skill, single wall homes became less common. An irony about single wall construction is that they have less bugs, don't need air conditioning, and are cheaper in the long run. Single wall homes typically have no fiberglass insulation and often do not have any drywall, both of which are some of the less earth friendly of all building materials.
Where am I going with this? Off on a tangent of course.
I'd like to think we as humans have the option to build our exterior with single or double construction. It's easier and far more common to go double-wall, first framing our boundaries, then attaching osb, a moisture barrier, and an exterior siding. At that point we go about our business of insulating, drywalling, taping, painting, and installing floors and baseboard. When we are done, we feel strong and protected, and we can open our front door to any of our friends who ring the doorbell or text us that they are stopping by to visit.
By contrast, the single wall human takes a bit more thought and work. Any gaps will be very noticeable, so the joints between boards and all of the angles which are exposed should maintain tight tolerances. Electrical wires have to be concealed behind casing, and plumbing routed entirely under the floor. A lot less material is used, but more time and care must go into the process of building, a process of delayed gratification.
As a child, I never appreciated single wall construction. I thumbed my nose at any homes that looked so "cheap". I erroneously assumed that drywall was "right". I did not fully appreciate the simple beauty that was all around me, single wall homes just seemed like a construction project waiting for funding.
But I do remember how it felt to be inside one of those homes. How connected to the island you feel when the tradewinds sing through, and how much you hear through the openness of the walls. In many ways, this feeling, the single wall feeling, describes what I feel in yoga, of connecting myself to the outside, while remaining indoors.
The privileges of a childhood in paradise are numerous because of all the uniqueness which simply cannot survive elsewhere. Unique species, unique construction methods, unique family units, and unique and breathtaking views of natural wonder. And yet, while the specifics of Hawaii's uniqueness cannot be directly experienced on the mainland, the conceptual approach to openness and connection is an option for everyone no matter where they are. We can always extend ourselves to others in various ways without giving up much of anything from ourselves. We can always get by with less, less stuff, less food, less time, less praise. We can always feel more connected to the world, by removing barriers between ourselves and that which we seek to be closer to.
One of my favorite memories of home, of being in a place I will always call home, is running past a single wall house, as the afternoon showers rinse my skin, and feeling an intense connection to the life flowing all around me.
Posted by The Suffer Seeker at 2:40 PM
http://daveeasa.blogspot.com/2011/11...struction.html
all this means jack sh^t
Tom Struble is offline
Old 10-08-2017, 01:58 PM   #42
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 42
You laugh at of what you don't know. The old Japanese carpenter that built this island really knew what they were doing!! The siding on the home I live in is the siding on the outside and the interior wall on inside. The wall is " thick. No water comes through the wall!!!!![/url]
No the catch is it can dry out quickly & is perfect in your climate. The thing is we used to build that way everywhere for years & never had issues though we had to use a ton of wood, then coal, oil, etc... to keep them warm (not really an island issue.) The problem is we started adding things into the walls to help keep some of that heat in & guess what - heat & thus moisture couldn't move through as freely & things rot. One other problem is we also don't use local durable woods but rather super quick grown pine
As for my walls don't leak - standard rule of thumb for all types is 1% gets by for a properly well-done assembly (no it doesn't matter what type) - you might not see it, but it is there
SLSTech is online now
The Following 3 Users Say Thank You to SLSTech For This Useful Post:
Philament (10-15-2017), Rio (10-15-2017), SmallTownGuy (10-08-2017)
Old 10-08-2017, 02:01 PM   #43
Dirtywhiteboy's Avatar
Rewards Points: 7,878
Originally Posted by Tom Struble View Post
Let me repeat myself " If water is getting in back of MY siding I have done something very wrong"
You'd look around with a confused look on your face if you ever came out here
That being said we do now install full paper, flashing tape, Tyvek , Tyvek tape & all. But yea when we are done with the siding it being hardie or LP smart side or ply T-1-11 it's water tight.
On the old homes:;: Oh but the high end homes had 1"X13" red wood heart wood walls.
The " thick walls hold up the roof
And the use of Canec (pronounced CANE-ick) is a building material that was used in the 1930s to the 1960s on Oahu would really get your eyes
Dirtywhiteboy is offline
Old 10-08-2017, 03:05 PM   #44
Stilla's Avatar
Trade: Finish carpentry
Rewards Points: 598
Koo ok
Originally Posted by SmallTownGuy View Post
What effect if any does hanging the product vertically have on warranty?
The warranty will still stand, the vertical lap joint is 5 inches, versus a horizontal lap joint, wihich is 2 inches. Vertical is more material, horizontal is more labor. Vertical is a one man job, horizontal is a 2 man job.
A 5 inch lap joint is 10 inches of material, vs 2 inch which is 4.
Stilla is offline
The Following User Says Thank You to Stilla For This Useful Post:
Old 10-08-2017, 03:37 PM   #45
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 8,178
Originally Posted by Stilla View Post
Koo ok
No pics or vid of you & others handling the material?
Would be interesting to observe.
"Your talent is God's gift to you. What you do with it is your gift back to God." - Leo Buscaglia
SmallTownGuy is online now
Old 10-08-2017, 03:52 PM   #46
Stilla's Avatar
Rewards Points: 598
I would have already shared images, my phone, which I use to capture the work I do, died. I have a new phone and will attempt to show what we felt was expediting the process. I would be happy to share, tomorrow.
Stilla is offline
Old 10-08-2017, 03:52 PM   #47
Here on the Henry Company video it says over lap 2"....
I've used it and with the split backing it's not that bad. It's just like peel&stick with split backing. There is a knack to it..
Self-Adhered Water Resistive Air Barrier Membrane, (house wrap.)-img_20171001_100050799.jpg
Old 10-08-2017, 04:28 PM   #48
Stilla's Avatar
Rewards Points: 598
https://youtu.be/4dbZhKy-I7M
What do you trust more, the video or the language written in the install instructions, that you can download off the official website?
Even better, the video you showcased was from 2014. I GUESS the company has not evolved in 3 years.
Stilla is offline
Old 10-08-2017, 07:34 PM   #49
I would go with the video because I'm not into reading long instructions on something as simple as peel&stick. If the video is no good I wonder why Henry doesn't take it down? 2 inches 3 inches or 6 inches as long as it over laps, it's peel&stick According to this guy you need a blue skin rep to come to the site and train you to apply it for the warranty to be effective. You have to apply for the Warranty and this is less than a year old. Have you been trained?? Are you a true Blue Contractor
Old 10-14-2017, 03:26 PM   #50
Stilla's Avatar
Rewards Points: 598
I have attempted to post images to this post, even corrected the images with an app, but that doesn't work. Every image is perpendicular, sorry.
I have worked with blue skin for some time now.
It's been about 2 weeks, and we, (1 who has over 30 years experience,) have not even completely finished the first floor. The labor is almost 4 times that of Tyvek. It's like wrapping Christmas presents with an adhesive backed wrap.
Some people are really good at wrapping presents, some are not.
After some time I came to the realization, that the material isn't strait. You can revive material that has a pretty hefty crown. Over 10 feet, I have seen a crown of 2 inches. That's a problem for the lap joint.
You have to correct for the Manufacturing faults befour you stick this stuff, meaning don't peel the film, untill you know exactly how it is hanging.
Like I said hanging it vertically is less work.
Self-Adhered Water Resistive Air Barrier Membrane, (house wrap.)-1508009128890.jpg   Self-Adhered Water Resistive Air Barrier Membrane, (house wrap.)-1508009154698.jpg   Self-Adhered Water Resistive Air Barrier Membrane, (house wrap.)-1508009174232.jpg   Self-Adhered Water Resistive Air Barrier Membrane, (house wrap.)-1508009195275.jpg
Stilla is offline
The Following 3 Users Say Thank You to Stilla For This Useful Post:
Philament (10-15-2017), Rio (10-15-2017), SmallTownGuy (10-14-2017)
Old 10-14-2017, 03:31 PM   #51
Stilla's Avatar
Rewards Points: 598
More pics.
Self-Adhered Water Resistive Air Barrier Membrane, (house wrap.)-1508009365240.jpg   Self-Adhered Water Resistive Air Barrier Membrane, (house wrap.)-1508009379372.jpg   Self-Adhered Water Resistive Air Barrier Membrane, (house wrap.)-1508009407956.jpg
Stilla is offline
Old 10-14-2017, 03:33 PM   #52
OK where can I see the install instructions,,, linky please...
Old 10-14-2017, 04:00 PM   #53
Stilla's Avatar
Rewards Points: 598
Dirty, you don't like to read, like you said. I GUESS goggle is to much typing as well. I am expressing my experiences with the material. I will not play daycare for contractors, find it yourself if you care.
Stilla is offline
Old 10-14-2017, 04:02 PM   #54
I can't find it ,, that's why I asked.... Help a guy out here??? I want to learn.
Old 10-14-2017, 04:08 PM   #55
John the Builder
https://us.henry.com/fileadmin/pdf/c...c_techdata.pdf
https://us.henry.com/fileadmin/pdf/l...Guidelines.pdf
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Stilla (10-14-2017)
Old 10-14-2017, 04:16 PM   #56
Oh I saw those from 2014 and 15,, I thought they might a some up to date instructions I could get the newest info from.
Old 10-14-2017, 04:21 PM   #57
John the Builder
I will say this: when it comes to the warranty - what is written takes precedence over oral guidance - like what a Henry rep said on site. And what is most current in written takes precedence over any prior written material - even if said material can be picked up off a store counter at time of purchase.
Old 10-14-2017, 04:29 PM   #58
In the video @1:50 I post up there it says you need to be a true blue contractor for the life time warranty , that Henerys needs to come out and train the guys??? Do you think that is still true??? Sounds like a catch to me.
Old 10-14-2017, 04:59 PM   #59
Stilla's Avatar
Rewards Points: 598
We had a training guy come out to our job. He was an idiot. He had no presentation, no helpful hints. I read the instructions, and moved on from there.
Stilla is offline
Rio (10-15-2017)
Old 10-14-2017, 05:02 PM   #60
John the Builder
The same "gotcha" was my deciding factor with ZIP/Advantech. DO NOT USE. Stray one iota from specified matrials - asdhesives, laps, fastner schedule/depth - and they say buh bye to the warranty.
40 years ago, my buddy had to pay 4K out of pocket to a 3rd contractor because the shingles we put on - specced to use staples -some of the staples were not true to parallel to the run by 5 degrees.
And so the circuit court found him liable for the whole roof.
Even though a year later a class action suit against the shingle make bankrupted them.
All warranties are bull ****.
The Following 2 Users Say Thank You to SmallTownGuy For This Useful Post:
Dirtywhiteboy (10-14-2017), Stilla (10-14-2017)
Under sink water filters ? My house We Fix Houses Plumbing 8 11-22-2016 05:24 AM
Cutting house wrap around a steel lintel franzkh Windows, Siding and Doors 13 03-25-2016 11:53 AM
rigid foam and house wrap. which comes first woodworkbykirk Windows, Siding and Doors 19 11-14-2013 07:02 PM
3" PVC pipe dumpig water into sump pump - what is it? ggsubs Plumbing 9 06-06-2013 08:17 PM
Water under Tile Membrane Chltpondman General Discussion 5 01-22-2010 03:50 PM
