Raising A Porch Roof
Old 05-07-2006, 01:19 AM   #1
paintr56's Avatar
Trade: paint contractor since 1974
I have a two story four square house with a front porch across the front. The posts suporting the roof have rotted and the porch roof has settled about 1 1/2" the roof extends out 8' from the house and is 25' long. I have put in temporary support posts I need to jack the porch back up and then put in permanent supports. I was thinking three screw jacks one at each corner and one in the middle and slowly raising it. Would this work or is there a better way?
Thank you for any help Jim Bunton Bunton Painting
paintr56 is offline
Old 05-07-2006, 08:11 AM   #2
Soon to be senile
Shamrock's Avatar
Trade: Remodel and repair
Re: Raising A Porch Roof
I've done several like you describe and they generally go back up pretty easy. The main thing is that your cribbing/ support is rock solid and your jacks are not over-extended and rated well above the estimated lift weight . I also set up some solid bracing in the event of a cribbing or jack failure (never happened but scares the hell out of me to think about it).
Shamrock is offline
Old 05-07-2006, 08:32 AM   #3
AtlanticWBConst's Avatar
Hi,
I would also suggest that you add a solid peice of lumber to "Lineate" the roof your raising.
What I mean is: Like a 2x6, 2x8, or 2x10 or an LVL laid flat, between your jack points and the roof line:
ROOF/ROOF/ROOF
_______________ (2x8 or LVL - Laid Flat)
1 2 3 (Jack Points)
That way you are raising the whole roof line - together. Rather than at only those 3 points. By raising only the 3 points, you could 'pull' those 3 points apart, if the area your jacks are under are weaker than they look.
Try to raise it all together, And do it slowly - so that the frame that has settled over the years, does not overstress too quickly.
- Build Well -
AtlanticWBConst is offline
Old 05-07-2006, 01:53 PM   #4
Soon to be senile
Shamrock's Avatar
Originally Posted by AtlanticWBConst
Hi,
ROOF/ROOF/ROOF
1 2 3 (Jack Points)
Good call...I normally work by myself so I sometimes forget how helpful another set or two of hands can be.
Shamrock is offline
Old 05-08-2006, 01:25 AM   #5
paintr56's Avatar
Very good suggestions from both Shamrock and AtlanticWBConst. I will run a 2x10 under the length to add support. and will raise at all three points at once a little at a time. There is allready a boxed beam running the full legth of the roof but I am not sure how strong this is so a little more can only help.
Thank you Jim Bunton
paintr56 is offline
Old 05-10-2006, 06:43 PM   #6
STEPHENMISHKA's Avatar
Trade: GENERAL CONTRACTOR... EXPERT WITNESS COMPANY
Having moved many structures, the most important construction elements to be concerned with is the size of the member to be seated below the elements to be lifted and under which the jacks are to be placed.
The Solender Group Inc.
Construction Defects Experts
STEPHENMISHKA is offline
Reverse gable porch roof Master Mechanic Framing 8 07-18-2007 11:10 PM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Raising a porch roof Ken@K&R Construction 4 02-22-2006 08:36 AM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
