Radiant Floor Homes
Old 02-25-2006, 11:48 AM   #1
Donedat's Avatar
Trade: Hardwood Flooring
Send a message via MSN to Donedat
Radiant Floor Homes
Starting to get trendy around here. Now that the technology is getting better we're seeing a lot more of these homes. They just come in and pour the foundation, black plastic, pink foam insulation, set their tubing and all other plumbing rough ins, pour their concrete, stamp per their design, and then frame it up.
I'm eager to get to do some hardwood in them. Some have tile, some have a combination of tile, carpet, hardwood, and even stamped concrete in some areas. These are mostly custom homes but I can see the spec home builders doing a few for a change in scenery.
I admit...I don't know everything...but don't tell my kids I told you.
Donedat is offline
Old 02-25-2006, 12:31 PM   #2
Steve Unkie's Avatar
Trade: REMODELING CONTRACTOR
Re: Radiant Floor Homes
Where I come from,AK, this was the norm for new high end const. Great for warm floors. Most would also do their garage, some would do their sidewalks and drives.
Steve Unkie.
Steve Unkie is offline
Old 02-26-2006, 11:34 AM   #3
TimNJ's Avatar
I put radiant on my first floor and I would never live without now. Technology and boiler design are important. Old tech, copper: , Mid tech, Heatway's glorified heaterhose , New tech, PEX
TimNJ is offline
Old 02-26-2006, 01:09 PM   #4
Priced In
JustaFramer's Avatar
Trade: Exiled For Life
I am have been thinking of doing something similar. Changing out the baseboard heat in my house for a hydronic system. Probably not radiant heat, I'll save that for when I build.
JustaFramer is offline
Old 02-27-2006, 09:47 AM   #5
RowdyRed94's Avatar
Trade: Residential custom home builder
They're quite common here, too. With all the interest in geothermal heat, in-floor ties right in.
Clint - carpenter, coordinator, webmaster
RowdyRed94 is offline
Old 02-27-2006, 11:02 AM   #6
Donedat's Avatar
I've been on small homes where they had installed electric radiant systems in the concrete floors. I've also watched tile guy install electric systems in bath under the tile. If you live in the natural gas zones, the systems are quite efficient $$$wise anyway. Oil is a little less or at least comparable to propane. Propane is ok if you purchase in large quantities.
We don't have the cold temps here to justify such elabortate systems, nonetheless, they're fun to watch being installed.
Donedat is offline
Old 02-27-2006, 11:34 AM   #7
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Yea, just about every high end new home up here has it.
Floorwizard is offline
radiant heat system maderuyck HVAC 4 08-17-2008 08:14 PM
Demo a foundation under a radiant heat slab without disturbing the slab...? wackman Remodeling 18 04-02-2007 12:38 AM
Wood Floor and Rosin Paper over Radiant cyepsen Flooring 2 03-08-2007 09:50 PM
Misc. Radiant Heating Parts phdboss1 Contractor Swap 1 08-20-2006 09:20 PM
Hardwood Floors over Radiant Heat bigtick Flooring 10 12-08-2005 03:43 PM
