R28 Value In 6.25" Cavity
Old 08-12-2006, 03:12 PM   #1
mas's Avatar
Trade: gc
Hi,
Im trying to get r28 value in a 2x8 rafter but there is 'provents' (a 1" plastic air baffel) in the cavity so normal pink insulation will not work..
does anyone know a product i could get an r28 or more value out of that will fit in a cavity of 6.25"
for most of the ceiling i just strapped it down.. to fit normal pink.. but there is a area that i cannot afford to loose any ceiling space
thanks
mas is offline
Old 08-12-2006, 03:54 PM   #2
mdshunk's Avatar
Re: R28 Value In 6.25" Cavity
PIC foam board is roughly R-6 per inch, depending on brand. That might be your only, time comsuming and expensive, option.
mdshunk is offline
Old 08-12-2006, 07:38 PM   #3
house bldr's Avatar
Trade: general contractor
you might try the spray foam insulation.I have not tried it but as I understand, it is about twice the cost of fiberglass and approx. r-7 per in.
house bldr is offline
Old 08-13-2006, 05:28 PM   #4
My custom title
Brushslingers's Avatar
Sounds like you are looking for a radient barrier.. combined with a standard R type insulation you could get 28 out of it.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 08-13-2006, 07:26 PM   #5
mas's Avatar
Trade: gc
i have a really bad inspector who is riding my ass because im young... He is making me bring up a 1912 house to modern insulation values. and its very hard.. I have already cladded the full house in 1.5" dow foam and now he is going after the roofs..
im gonna just gonna glue together a few peices of 1.5" foam (like the person above suggested) with a value R7.5 then foam them with some foam2foam inplace.
if he has a problem with that i will have to start the legal route to try and smarten him up
mas is offline
better header, lifting it....... ApgarNJ Framing 11 06-19-2007 11:56 AM
Where Do You Need Fireblock? Liquid Force Carpentry 11 06-13-2007 09:48 PM
shallow wall cavity gutrman Plumbing 1 02-08-2007 08:29 PM
