R-38 Insulation Install - Incorrect Installation
Old 02-20-2018, 10:58 AM   #1
Mickey1's Avatar
Trade: Environmental Remediation
Rewards Points: 2
I was recently called out to a home that was purchased four years ago..contractor bought it to flip. Put an addition and renovated the kitchen and adjoining bathroom. The drawings indicate 2 x 8 roof frame. 3/ 12 roof. No air baffles were noted on drawings. The drawings indicate R-30 fiberglass insulation. This was crossed out and R-38 was written in.
When I looked in kitchen every light fixture (ceiling is raised) including the ones at highest point have water stains, the joint tape is coming off. The accessable attic had 1/4 of frost on every piece of lumber including roof.
I know R-38 cannot be packed into a 2 x 8 roof frame cavity. It creates a moister build up. But WHAT IS THAT CALLED? When insulation is compacted, no air baffles, cold from roof acting on moisture from inside home entering this cavity there is No form of R value BUT What IS IT CALLED? Thank you.
Mickey1 is offline
Old 02-20-2018, 11:28 AM   #2
Tom M's Avatar
Rewards Points: 6,462
Re: R-38 Insulation Install - Incorrect Installation
Pick up the phone and call the architect. They never learn. I swear to they are getting lazy
Tom M is offline
Old 02-20-2018, 11:42 AM   #3
Philament's Avatar
Trade: Whatever the customer wants
Rewards Points: 2,176
I think you might be getting terms mixed up, but the technical term for this manifestation is called Interstitial Condensation.
If you're referring to an unvented roof assembly, sometimes people refer to the as "hot roofs"
Philament is offline
The Following User Says Thank You to Philament For This Useful Post:
AustinDB (02-24-2018)
Old 02-20-2018, 06:11 PM   #4
Box Builder
Morning Wood's Avatar
Rewards Points: 8,958
You need to verify what type of insulation the R38 is? Hot roof can't be done with fiberglass alone. Well, maybe, but not in a solid sawn rafter.
Morning Wood is offline
Old 02-23-2018, 11:49 AM   #5
Pangdev's Avatar
Trade: general contractor
Rewards Points: 188
Sounds like a mess.
Pangdev is offline
Old 03-15-2018, 08:41 PM   #6
wmullis0's Avatar
Trade: Electrical engineer
Rewards Points: 4
Dense pack?
wmullis0 is offline
Plenum Insulation Fire Rating ASMCHICO HVAC 3 06-22-2012 09:01 PM
